93 Z28 T56 running well.....
Old May 26, 2021 | 08:02 PM
Gone Antique's Avatar
Hello, I wanted to post and help any way I can. I know my car inside and out.... Thanks for letting me join....
Old May 26, 2021 | 08:08 PM
Re: 93 Z28 T56 running well.....
I opted to increase compression to 11.5 /1. By installing a balanced, forged rotating assembly. 3.75 crank. And have the ability to add a 200hp shot of nitrous later.
Old May 26, 2021 | 08:34 PM
Also I wanted to add. I’ve had my car for 28 years!!!! It’s been keyed before, someone stuck something in the fender well and pried my bumper, and the alarm used to go off all the time. But I made it to the car shows.....
Old May 26, 2021 | 08:47 PM
Here’s my amplifier I had hooked up but I downsized to save weight..... It was only rated 50 watts x 4 channels...
Old May 26, 2021 | 11:45 PM
Appears you started a new account because your earlier post did not appear. It didn’t appear because something in the post put it into the “Moderation” queu.
I can approve that post if you would prefer to keep your old account.
Old May 27, 2021 | 07:53 AM
Thanks, ya I flew off the handle a few times, during a previous build. But I have it all working well now.
Just did an Opti swap this spring. Fresh AC Delco....
I cleaned the TB later. I was getting a hard start/backfire. Then changed my coil and connector... Did I mention the last two digits in my VIN are “28”!!!
Old May 27, 2021 | 07:57 AM
My machine shop did a great job taking it .30 over. Ring end gap checked out. He found something not lining up on a main cap and fixed it. I double checked with plastic gauge...
Old May 27, 2021 | 07:58 AM
Don’t forget to prime the oil pump on assembly completion....
Old May 27, 2021 | 08:26 AM
I installed a Denon CD player with 24 times processing, tuned for AM/FM reception. Paired with an Alpine DSP and MB Quart components....
Old May 27, 2021 | 04:26 PM
https://www.roadandtrack.com/car-cul...1ZINbYM0SU61ZY
Old May 27, 2021 | 06:55 PM
Went for a test and tune cruise. When I got back, a mouse appeared on the windshield, then hoped back down the hole at the base of the wiper. “Rat Fink”?
I never drive it’s a statue.
milage: 89,866
rebuilt engine and clutch assembly, around 5k ago.
everything is working as it should. It’s all been replaced with AC Delco gaskets and sensors.
Old May 27, 2021 | 07:10 PM
Here’s a list of mods:
373 Richmond gears in the rear
Mcleod Aluminum flywheel
Roller pilot-bearing
McLeod Clutch and new master/slave cylinders
Wiseco forged pistons .30 over
Pro Comp 5.7 forged rods
Sun DF forged 3.75 crank
Hi-pressure GM oil pump
Roller tip rocker 1.6 ratio
Hardend push rods with GM guide plates
Stiffer valve springs
31# Bosch injectors
Solomon tune
Under drive crank pulley with a stainless keyed hub
new timing chain
SLP mid-length headers
Borla Cat-back stainless exhaust
Holley 58mm TB with matched intake plenum
KYB shocks
Eibach springs
R.O.H. rally wheels
Mickey Thompson tires
Ice cold AC
Stock heads and cam after all it’s a street/show car.
And the typical stuff like a new radiator and opti this spring.
On order: Casper’s fan harness and switch. Even though my fans work as they should, I would like to over ride and have them both on when need be.
Ready for NOS!!
Old May 27, 2021 | 07:22 PM
I took it to the raceway right away after a quick engine break-in and I got all the lithium assembly lube out of the oil pump I packed it with.
The sun was setting and the cool air started to drop onto the drag strip.
A mustang pulled up beside me. I did a little forty yard burnout and the race official jumped behind the wall.....
A guy walks down from the stand on my side and holds up a big roll of money.
Then a guy on the mustangs side nodded his head.
I beat that mustang by a bumper!!!!
Old May 27, 2021 | 09:38 PM
I just got my second COVID vaccine today. So wanted to post in case I don’t wake up tomorrow. My wife helped me put my factory hood back on.
Old May 27, 2021 | 09:44 PM
This paint is over twenty years old....Needs to go to the right a little, I know, it was a pain...
