New England Area For members in Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, and Vermont.
post header install problems...
Old Jun 6, 2004 | 04:44 PM
Got-LT1?'s Avatar
Hey guys,
finished installing my headers yesterday... what a pain in the butt it was... Jet-hot LTs, Hooker Y, Taylor OVC kit, new NKG Tr55r plugs, new 02 sensors and simulators...
I have a few concerns that are making me less than happy... The headers dont appear to be leaking at any place, but the noise in the enging bay is considerablly louder (too be expected i'd assume) my problem is that when i accelerate at approximatlye 2400Rpms to 3000RPMs it feels like the motor is missing or stumbling... and it gets quite a bit louder at that rpm range, after that it smooths out and pulls very hard... im not a very experienced mechanic so im having trouble diagnosing the problem, i dont get any SES lights but i am concerned none the less. Also i can smell gas in my exhaust much more than before, likely because i dont have a Catalytic converter anymore...
My guess is that its a problem with the taylor wires, perhaps grounding out or not making good contact... i was not pleased with how that came out, ie 2 of them seemed kinda sketchy... Maybe i should buy a new set of wires and try it? something that isn't as much of a pain as the taylors!!!
If anyone could perhaps give me some advice that would be very helpfull... Because right now im kinda discouraged and regretting doing the headers.... lots of work, money, and effort for a car that doesn't seem to be running as good as it was before
I was kinda hoping that i might go to the track (NED) this friday or next and see some of you more experienced guys there, and perhaps have one of you guys give it a listen just to get a seccond opinion... Cause most of you have probably gone through what im up against
thanks, matt
Old Jun 6, 2004 | 07:11 PM
Like My Taillights?'s Avatar
Sounds like the problem to me, look at the motor running in the dark to see if you get any arcing. Did you get an LT4 knock module while you were at it? Just my .02, which usually isn't even worth that much. Good luck though. Rob
Old Jun 6, 2004 | 07:48 PM
Got-LT1?'s Avatar
yea i might just yank the taylors out next weekend... i wasn't really all that pleased with the kit as a whole... i guess ill look into the lt4 KM as well...
thanks, any other ideas or people who are near bye and want to give it a listen ?
Old Jun 7, 2004 | 07:55 PM
naztyz28's Avatar
your from dover? i usually there on the weekends
Old Jun 7, 2004 | 08:34 PM
Kataklysm's Avatar
Are the headers cracked? I used to smell gas hardcore then the header finally just broke and I realized it was cracked the whole time.
Old Jun 7, 2004 | 09:10 PM
Got-LT1?'s Avatar
nazty, yea i go to UNH and i live in dover, where you from?
kataklysm, good crap i hope the headers arn't cracked that would suck!!! i dont think they are because i dont hear any bad leaks, or so i think .... hmmm
Old Jun 8, 2004 | 01:49 PM
Kataklysm's Avatar
I didn't hear any leaks from mine, it broke around the EGR fitting. Poke your head around and see where its coming from. If its not an exhaust leak you have a serious fuel problem that is not good.
Old Jun 8, 2004 | 03:08 PM
LastYearZ28's Avatar
Im in Portsmouth, I could give it a lok and listen. All my tools are at work but I will be able to tell you if its missing, like a bad wire.
Old Jun 8, 2004 | 03:12 PM
Also those headers could be leaking at the collector and it resonated into the bay, or your header gasket might not be seated properly, what kind of gasket did you use and was it new or used.
Old Jun 8, 2004 | 03:19 PM
I keep thinking of more things, I really need to see and hear it. If it was a material gasket VS. a metal i.e. copper gasket or if it was material with copper or steel sleves around the tubes they sometime have bad sealing issues, if it was a copper than as long as the bolts threaded your ok. Also did you torgue the header bolts, if so to what ft/lb or in/lb, did any of the bols go in hard and did use use a anti-sieze lube and or any threadlocker. These are things I need to know when I see the car, also was there a gasket where the headers met the mid/cat pipe, again were they material or a thick metal ring at the flange?
Damn I just need to see it. Sorry for al the posts!!!
Old Jun 8, 2004 | 04:51 PM
naztyz28's Avatar
my g/f is goin to culinary school there (dover)
dmcdonald96
Jan 30, 2015 06:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
GigaMp3z
Feb 20, 2003 02:57 PM
