New England Area For members in Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, and Vermont.
EWP problems ???
Old May 23, 2004 | 05:10 AM
bowtiepwr's Avatar
Question EWP problems ???
>anyone here have difficulties with their elec water pump ?
I have a Meziere and it doesn't seem to working (disconnected it from the relay ... direct wire to the battery and ground) .
any thoughts ?
Old May 23, 2004 | 09:26 AM
Slowhawk's Avatar
Installed 4 of them with no problems.You might have a bad motor in yours.Also they are extremely quiet.
Old May 23, 2004 | 04:16 PM
bowtiepwr's Avatar
>I would think that you would still feel a vibration from the housing of the ewp .
I will remove it and bench check it at work ... thanks
Old May 23, 2004 | 04:30 PM
Slowhawk's Avatar
You should see the water moving in the radiator.
Old May 24, 2004 | 04:32 AM
bowtiepwr's Avatar
>That won't happen until the thermostat open right ?
Old May 24, 2004 | 01:47 PM
Slowhawk's Avatar
for an electric water pump you have to drill a 3/32 hole in the thermastat to relieve pressure on the pump when the t-stat is not open.
Old May 28, 2004 | 07:50 PM
bowtiepwr's Avatar
>when the pump is running ... as you look at it (the word "Meziere") does it turn clock-wise or counter clock-wise ?
do the curved blades scoop the coolant or do they flow the other way ?
BTW - the reason that it wasn't working is because the wire from the fuse panel wasn't crimped all the way through the sheathing , so I fixed it by soddering the wires instead (stupid crimps )
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Jlo
Feb 3, 2015 09:41 PM
