For You LT1 Guys..
Old May 8, 2007 | 09:15 AM
  #16
Ray@NitroDaves's Avatar
The elbow was designed to use the stock stylr TB and out it as close as possible to the stock location.
THis solves multiple problems...throttle tip-in tuning....TB/MAF/Filter plumbing, you can reuse a stock style elbow and CAI.....and throttle cable issues.
This saves money over the usual single plane conversion as you do not need to purchase a new TB and custom fab a CAI
It also requires no cutting on the cowl for clearance.
Old May 8, 2007 | 09:17 AM
  #17
95ttoplt1's Avatar
Any word on if it will fit under a stock camaro hood??
Old May 8, 2007 | 09:21 AM
  #18
I have a spare hood and will talk to the owner to see about swapping hoods long enough to check.
The owner of the car pictured above has a cowl induction hood on it currently.
Old May 8, 2007 | 02:24 PM
  #19
95ttoplt1's Avatar
Great, I really want all my new goodies to fit under the stock bonnet
Old May 8, 2007 | 06:07 PM
  #20
My Iroc Z28's Avatar
It looks awsome, whats the price on it?
Old May 11, 2007 | 01:45 PM
  #21
Nitro Dave's Avatar
See post 13
Old May 12, 2007 | 06:54 PM
  #22
1badasZ's Avatar
do you have a time limit on how long you will be making these? looks like a really good setup. im trynna buy engine parts right now but definately want one of these
Old May 12, 2007 | 10:25 PM
  #23
CamaroRacing12's Avatar
koool setup...looks sweet under the hood to...btw what a nice looking LT1 that is huh?
Old May 13, 2007 | 11:51 PM
  #24
Loadre's Avatar
Looks like you need to mod the fuel system to run aftermarket rails and what not too.
Old May 14, 2007 | 09:04 AM
  #25
they make adaptors to go from the stock fuel lines to AN fittings....very easy to do
Old May 14, 2007 | 09:10 AM
  #26
Loadre's Avatar
Those aren't the stock rails though are they?
This is very tempting. Seems like all in all it's about $1000 to do it once you buy the intake and do machine work and have you all plumb it and fab the elbow. Not a bad price for not having to worry about running a large shot like you have to with the stock LT1 intake.
Old May 14, 2007 | 10:45 AM
  #27
Originally Posted by TurboSS
any chance of dyno numbers NA or altered b4 and after?
I will be doing this conversion on my 94...will have before and after dyno #...Matts car will only have #'s w/the elbow
Old May 14, 2007 | 10:46 AM
  #28
Old May 16, 2007 | 05:12 PM
  #29
ltwonz's Avatar
It looks good guys. I would like to see this set up with a direct port done.
Old May 24, 2007 | 06:18 PM
  #30
jakesz28's Avatar
I may have to get one of these when I do the stroker. I like the fact that you are using the thottle body and cold air. Are you going to be making these for a while or should I get it now?
Also on my current motor I have been using a single nozzle spraying a 150 shot I would like to up it to a 200 shot what would be the most cost effective way of doing that?My niods are good for 250hp.
