For You LT1 Guys..
For You LT1 Guys..
We recently built a set up for a local guy. WE will now offer these set ups.
We took the intake and plumbed spray bars into it for the Nitrous. Then we custom built the elbow.
With this Elbow and spray bar design there is no need to cut up your cowl.
I am not so sure a stock camaro hood will fit though.
What do you think?
Dave
What do you think?
Dave
It is the front of the elbow that will cause a clearence issue ...if any....the TB is 1-1.5" higher than stock.
Well we can't see the NOS...but thats good HE HE.
To see if it clears lay a 2x4 across the fenders, it will tell ya.
Cost for the conversion and complete system? Adjustable to 300 hp, With...
Trans tunnel bottle mounts
Bottle heater
Stand alone front mount fuel system
Blow down tube.
I already have the intake and elbow.
David
Bottle heater
Blow down tube.
David
Ok,
This intake is a Edelbrock Victor E. The intake comes with a Chevy small block bolt pattern. The intake has to be welded and re drilled to match the LT1 bolt pattern.
The customer had the machine shop do that part.
We took and installed spray bars in the intake. I forgot to take pictures of that. However it looks like the one in this picture but instead the bars and fittings are side to side instead of front to back.
http://www.nitrousoutlet.com/installs/install.asp?id=17
Then we custom built the elbow off of his car.
Cost to install spray bars is 250.00
The elbow is 300.00
Dave
The elbow is 300.00
Dave
The throttle cable bracket on the elbow, did you splice two cables together? Or am I looking at something else? I am trying to figure out how to get a cable on mine which is VERY similar, but I can't put mine up that high as the cable hits the underside of the cowl(mine is not as long, to the front of the car). If two cables are not spliced, how did you get the "throw" right so it pulls the throttle blade 100% open?
David
David
Good to see you haven't forgotten about us LTx guys.
