Would this Idea Work
Old Oct 31, 2004 | 08:50 PM
JOE96Z28SS's Avatar
One question I have with nitrous is why not build a Nitrous Nozzle that would extend a tube into the intake through the EGR port and create nozzles that fire directly at the intake ports. It would be stealth nobody would ever see it and it would require less work.
Old Oct 31, 2004 | 09:38 PM
ford's Avatar
Re: Would this Idea Work
Its been so long since i had EGR i dunno if i remember where the hell it is at anymore
Old Oct 31, 2004 | 09:40 PM
JOE96Z28SS's Avatar
Right in the back and the hole opens up right inside the plenum if you fashoned a tube with nozzles aimed directly at he intake ports it should be perfect
Old Nov 1, 2004 | 01:25 AM
kevmor99's Avatar
It would be better if you did a direct port on the inside of the intake
Old Dec 6, 2004 | 07:01 PM
Steve in Seattle's Avatar
like through the idle passages?
DirtyDaveW
Dec 1, 2016 05:37 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
