WOT switch location?
Old 09-18-2006, 01:12 AM
cc89formula's Avatar
anyone have pics of how they did it?
cc89formula is offline
Old 09-18-2006, 10:03 AM
Moshbmx1's Avatar
Re: WOT switch location?
I mounted mine on the firewall under the gas pedal..i dont have pics but i will try to take some if you want to see
Moshbmx1 is offline
Old 09-18-2006, 01:16 PM
2000GTP's Avatar
I ordered the custom billet bracket from www.nitrousoutlet.com The bracket comes with an attached WOT switch and it is bolted right to the throttle body. I don't have any installed pics., just what it looks like out of the box.
2000GTP is offline
Old 09-18-2006, 02:58 PM
WhyHelloOfficer's Avatar
I keep mine in my glove box
If you're trying to make your setup somewhat hidden.. an electronic TPS Switch is definately the way to go. All you have to do is tap into the TPS signal wire going to the PCM.
If you want more of my hidden setup I'll PM you some links to pics.
WhyHelloOfficer is offline
Old 09-18-2006, 03:04 PM
i dont want to spend money on something like that, i already have the WOT switch, and my systems not going to be hidden anyway, its hard to hide a plate kit...plus my bottle is mounted on the hump between the rear seats
meissen
06-01-2015 07:59 AM
taner
08-26-2002 10:58 PM
taner
08-23-2002 05:25 PM
taner
08-21-2002 09:49 AM
taner
08-18-2002 08:43 PM
Quick Reply: WOT switch location?
