Window switches and retard boxes
Old Apr 2, 2006 | 04:55 PM
  #16
CamaroSS30thAnn's Avatar
Re: Window switches and retard boxes
Originally Posted by Z28_95RIDE
Thanks Chip! It looks like my 95 will need the 8876 MSD harness and CamaroSS30thAnn will need the 8877 but I will have to take a look for the dual connection on mine.
As for your question CamaroSS30thAnn, it seem that the integrated window switch can be used to enable the n20 arming switch but someone else will have to give an experienced answer. I'm really glad you started this thread btw.
so the mallory 685 and msd wirig harness 8877 and its straigh up plug and play eh
right one?
http://store.summitracing.com/partde...0&autoview=sku
i assume mines a single connector?
Old Apr 2, 2006 | 06:42 PM
  #17
Z28_95RIDE's Avatar
right one?
This is what I'm trying to figure out. It seems there was a change starting in 1996. I went to http://shbox.com looking for the views but I'm not certain what I'm looking for just yet. There is a view for the optispark harness for my 95 here: http://shbox.com/1/evap_sol.jpg but I'm not convinced this is where the msd harness would intersect. I'm embarrassed to say that I don't know what or where to look for a coil on this engine although I was under the car today, I saw nothing but the bottom of the optispark, air pump and overhanging water pump. It's something I haven't had to deal with until now. Hoping someone will guide us along at this point.
Old Apr 2, 2006 | 07:30 PM
  #18
Z28_95RIDE's Avatar
Wait one. Here's the link to the coil; http://shbox.com/coil/coil.html as Rob comes through again....
I will have to wait until tomorrow to get a good look at it though. Too dark now and I have to determine if access is from the bottom or top. Really sure it is from the top. I think I need to remove some of my CAI ducting. I need to figure out exactly what is meant by dual connection.
Old Apr 3, 2006 | 08:36 PM
  #19
summit websites says the 8876 is for vehciles 86 or 87-95 and the 8877 for 96-2000
i took a jump and ordered the mallory 685 and the msd 8877 tonight, i hope all works out for me
now heres one more question , how does the box know when to retard the timing and when not to , say im not spraying will it still retard or not???
Old Apr 7, 2006 | 09:38 AM
  #20
Joe B's Avatar
The box has an extra wire lead comming out of it...and "only" when that wire gets 12 volts applied to it, the retard circuit will then be active, and will retard the timing to where you have it set.......the nitrous arming switch is a good location for it.....
Old Apr 7, 2006 | 03:08 PM
  #21
gotcha , parts came in already , summit is very quick at deliveries, since they are only like 4 hours from the house,
cant wait to get my car inspected and my buddy has time ,i have a lot of work to do
Old Apr 8, 2006 | 07:01 AM
  #22
Z28_95RIDE's Avatar
Please post your results and observations. I'm interested in your project here. Good luck and I hope everything goes well.
Old Apr 8, 2006 | 11:28 AM
  #23
alrght ill let u know , it will be a few weeks since my friend has been busy and so have i , ill let u know
Old Apr 8, 2006 | 01:48 PM
  #24
Z28_95RIDE's Avatar
Here's something I found here that might prove useful as you connect the Mallory into the MSD harness:
Connecting MSD harness to Mallory Harness MSD to Mallory:
(MSD)Red to (MALLORY)Red
(MSD)Black to (MALLORY)Black
(MSD)White to (MALLORY)Green
(MSD)Orange to (MALLORY)Yellow
Obviously I can't verify the correctness of this but just to let you know there are some wire color differences to deal with.
Old Apr 8, 2006 | 04:23 PM
  #25
thanks man ,this may come in handy
Old Apr 8, 2006 | 06:14 PM
  #26
Owens Racing™'s Avatar
I use the Mallory 685 myself. It is the perfect box for any application, N20 or boost. It has a boost retard, along with a single retard, the built in window switch, and the best is a secondary retard for launch or burn outs.
I personally wired this direct. Hard wired using solder and heat shrink. Mounting position was located in the glove box.
http://home.comcast.net/~owensracing/P1000074.JPG
Sorta a crappy pic, but you get the jest. I made an Aluminum plate and mounted it with double stick tape.
If you have any question on mounting or wiring i will try to help.
hit my email at owensracing@comcast.net
Thanks,
Jeff
Old Apr 8, 2006 | 07:38 PM
  #27
Bow94z's Avatar
Where did you find this at?
Old Apr 8, 2006 | 09:19 PM
  #28
Thanks,
Jeff
u people are frickin awesome
Old Apr 10, 2006 | 05:12 AM
  #29
Z28_95RIDE's Avatar
http://web.camaross.com/forums/showt...lory+connector
Old Apr 10, 2006 | 08:00 AM
  #30
speedmiser's Avatar
One nice thing about using the msd harness - if you run into problems down the road and need to troubleshoot to see if the ignition box is working for whatever reason, you can unplug the msd harness and plug in the stock harness, bypassing your ignition box, without rewiring.
Heathen1
Jan 2, 2016 04:27 PM
willismoons
May 27, 2015 04:03 PM
x7x7
Aug 15, 2002 06:49 PM
