Window Switch on LT1
Old Jun 22, 2005 | 01:22 AM
buzz12586's Avatar
Can I simply hook up a window switch like this one
http://www.dynotunenitrous.com/store...?idproduct=138
or do I need a complete MSD system in order to use it??
Old Jun 22, 2005 | 07:12 AM
whatsup's Avatar
Re: Window Switch on LT1
No, you do not need a MSD system to run a window switch. That looks like it should work. I would suggest running it WITH a WOT switch.
Old Jun 22, 2005 | 09:12 AM
Nitro Dave's Avatar
You will not need anything else to wire that up.WE sell these MSD Digitals for 95.00.We also carry the BMN controller.THe BMN unit has a fisrt gear lock out option that is perfect for traction limitied applications.This unit is 129.00.
Dave
Old Jun 22, 2005 | 09:24 AM
BlownF1's Avatar
I see it says that it has "normally open" and "normally closed" contacts. Are they straight through relay contacts with both lines available, or is one tied to ground internally so that the unit either connects or disconnects ground? If it's simply relay contact I'll have to keep that one in mind next time I need one. It looks pretty slick and I hate the ones that force you to use ground or add an external relay...and MSD's pill thing...what a scam! The Mallory is currently my window switch of choice, but this one looks promising.
Old Jun 22, 2005 | 09:47 AM
buzz12586's Avatar
Does the one with the first gear lockout work with a manual tranny as well?
MichiganSkip
Aug 31, 2002 08:52 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
