will this hold
Old May 12, 2004 | 12:25 PM
1984camaroz28's Avatar
will this hold
383 cask crank
hyp pistons 11 to 1
will this setup hold a 100 shot or even a 150 shot
Old May 12, 2004 | 01:26 PM
BIGBADBOWTIE's Avatar
If you used good fasterners.. yes.... I run 125 on cast gm crank,GM rods, KB hypers.
Old May 12, 2004 | 11:35 PM
But will this piston hold a 100 shot possible a 150 shot
Piston
Old May 13, 2004 | 05:14 AM
RacinLT1's Avatar
as long as the tune up/fuel system/ignition system are good,there should not be a problem with those and a 150 shot.
i ran a 175 shot for 4-5 months and a 150 shot for 2+ years on a set of stock hyper. pistons and had no damage.
Old May 13, 2004 | 06:51 AM
As racing said they will hold(make sure your stuff is up to par).I run the KB piston in my 355. Many bottles later its still running strong!!!
Old May 13, 2004 | 12:59 PM
rskrause's Avatar
Moderator
I don't believe this is an appropriate piston. Isn't it a light weight piston designed for a "restricted" 2bbl application? Call KB and talk to them before going ahead.
Rich Krause
Old May 13, 2004 | 01:07 PM
krause... you da man..
I just assumed when he said hyper in the above post that link was to a KB HYPER piston not a CLAIMER. As krause pointed out you might want to rethink that piston choice.
Guess I better not assume anymore....
Old May 13, 2004 | 01:16 PM
i found a forged pistons... but its only 10.75 to 1 im really looking for 11 to 1 with a 64 cc head .. trick flow heads. can i run more and still be safe with the cc306
Old May 14, 2004 | 02:13 AM
david97gsxr's Avatar
if you're really after 11 to 1 c/r, you could have the heads milled or shaved or whatever it's called. i don't know the exact number, but for like ever .006 you shave off. it decreases your combustion chamber by 1cc, and decreasing the combustion chamber CC will raise the c/r.
you'll have to do a search to find out the exact amount to shave off to get what you want.
Old May 15, 2004 | 08:54 AM
i realy dont wana mill the heads or anything like that yet
Old May 15, 2004 | 11:56 PM
RacinLT1's Avatar
you will not miss/notice a .25 point of compression. run the forged piston,or cut the heads,or get a custom piston. cheapest of the 3 will be running the 10.75:1.
Old May 16, 2004 | 09:01 AM
Arrow
ok thank you
LT14LIFE
Nov 15, 2015 06:22 PM
PopoFormula
Oct 12, 2015 04:19 PM
CARiD
Sep 30, 2015 05:44 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
350350
14
Aug 11, 2015 12:03 PM
