why on at 3000 rpm
because, it is the 'safe' thing to tell people over the internet. even the nitrous companies have it in their manuals now that say no lower than 2500 rpms. i've hit it as low as 1800 rpms in my cars.
Sorry, more details needed i guess.
The cylinders don't draw in enough N2o to burn it all, some gets left behind in the intake. The same amount of N2o gets spray'd at 1,000rpm as 6,000, depending on how much cylinder volume you have and how much n2o your spraying will effect how soon you can begin spray the N2o safely. 3,000rpm is the "safe" area for all engines. Your engine, your choice.
so it seems 2500 is the safe limit they speak of. i know it has to be at WOT. i am not a nitrous newbie by any means. just have never sprayed a lt1.
a 50 shot at 2000 would prolly be ok, a 100 at 2500...but thing is the lower rpm you hit it that bigger the tq spike...and that wil be what kills your motor...a 50 shot with a stock stall at say 1500 rpm will probably make 125 ft lb of torque...a 150 shot at the same condition would probably make 350 ft lb of tq...
add 350 to your stock 300 or so, and thats 650 ft lb on a stock bottom end...
ls1tech talks about this a few differant times...exspecially robert56, he dailed in a stock ls1 bottom end to stay together for over 2 years on a 250 shot...by breaking it up i think 150 at 300, and another 100 at 4500...trying to keep both tq spikes under 650 ft lb...
that all is only about keeping your motor together...that has nothing to do with the possibility of detination or backfire...
The cylinder pressure increase is proportionate to hp and inversely proportional to rpm.
Example: engine makes 200hp at 2,000rpm, producing "X" lbs of cylinder pressure. At 4,000rpm, the engine makes 400hp, cylinder pressure also = X.
Add a 200hp nitrous shot at 2,000rpm and cylinder pressure doubles to 2X. Add it at 4,000rpm and pressure increases to just 1.5X. The lower you bring the nitrous in, the greater the increase in cylinder pressure, which is what breaks stuff.
Rich
Rich
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
