Who with an A4 is running nitrous w/o a Window Swith????
Old Jul 26, 2002 | 11:12 AM
KamaroL98's Avatar
Arrow Who with an A4 is running nitrous w/o a Window Swith????
I am getting one sooner or later, but has anyone hit their rev limiter yet becaus they didnt have one to shut off the nitrous? Everyone is saying its crazy not to have one....
Arctic White 1998 Z28 Camaro LS1 A4
3.42 Gears, LS1 Motor sports Lid, Exhaust,
NOS Dry Kit.
Old Jul 26, 2002 | 12:01 PM
n2oTransAmLT1's Avatar
Post
My buddies GTP (A4) has been running a 100 shot wet NOS system without a window switch for 1.5 yrs. However, he has gone through 4 race trannys. His car shifts fine, does not hit the limiter but tears trannys apart. Get it when you have a chance, its worth the $80.
`96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M shifter, Walbro in-line fuel booster pump, Granatelli MAF, 52mm TB w/Airfoil and coolent bypass, LT4 KM + programmed computer, Accel 8.8 race wires, Zex Hyperformance plugs, MSD Univ. Adj. timing, Window switch, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, !CAGS, Yokohama tires, tinted windows.
Low 13's on motor.
Low 12's on bottle.
"Lots of throttle and a backup bottle"
Old Jul 26, 2002 | 12:31 PM
Derrick Redd's Avatar
Post
I launch off the bottle using my 3,600 stall as a window switch for down low. I have not hit the rev limiter yet on the top end. I have my shift light set about 300 rpm's early, because when on the dope they come up pretty quick.
<A HREF="http://personal.msy.bellsouth.net/msy/k/r/kraest/derrick.htm" TARGET=_blank>1994 Z28 A4
LT1 Motorsports equipped stock-bottom end LT1, LT1 heads, Hydraulic-Roller Cam, Dope
11.03 @ 125.53 1.61 60ft.
7.08 @ 99.05 1/8 mile</A>
1984 Mustang L
92' 5.0 roller motor, T5, NOS plate kit, etc.
14.03 @ 100.51 2.29 60ft. NA on street tires
Dope with slicks ????
Old Jul 26, 2002 | 12:37 PM
RacinLT1's Avatar
Post
I never ran a window switch and i do spray through the shifts. NEVER hit the rev limiter,stock trans lasted about 4 months doing that. Had the trans rebuilt by 12SCNDZ and it is holding up great. Still spraying through the shifts with about 50-60 nitrous runs and countless n/a runs.
I am swapping to a TransBraked 700r4 this winter and i still wont plan on running a window switch.
Dirk
1997 TA A4
11.251@119.3 1.52 60',7.132@95.39 1/8
The RacinLT1
RacinLT1 pic's
Old Jul 26, 2002 | 03:59 PM
KamaroL98's Avatar
Post
Id ratrher buy a window switch then have my tranny go out after 6 monthes or so....
NOS Dry Kit.
Old Jul 26, 2002 | 04:03 PM
RacinLT1's Avatar
Post
The new trans is going on 6 months of abuse,fluid looks like new. I knew the stock trans wasnt gonna last spraying through the shifts.
Old Jul 26, 2002 | 04:28 PM
gb95zconv's Avatar
Post
The rev limiter is there for a reason.....stuff happens engine over revs...limiter prevents damage to engine. Not a good thing when nitous is involved....thats where the window switch saves your tail. Its cheap insurance.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Old Jul 27, 2002 | 02:21 AM
rskrause's Avatar
Moderator
Post
Use a window switch.
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
bandit383lt4
Dec 21, 2014 09:12 PM
CaRParts102
Dec 6, 2014 08:45 AM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
