what should my fuel pressure be at?
Old Apr 9, 2003 | 09:32 AM
BlackbirdWS6's Avatar
i have a stock motor with some basic boltons. I have the TNT 100 shot wet kit with all the safety goodies. what fuel pressure should i be at and what is the best setting for my fpss to be at. thanks
Old Apr 9, 2003 | 07:11 PM
stik6shift98's Avatar
mines hangs around at 60 ish.....
Old Apr 9, 2003 | 07:14 PM
Dave 96TA's Avatar
on an LT1 you should expect between 43-45psi at idle.
Old Apr 9, 2003 | 07:20 PM
oh i was thinking ls1.....overlooked his sig...yes 45 is right
Old Apr 9, 2003 | 07:57 PM
ok cool, so i am looking for 45psi. now, what setting would be best to have on my fpss and what would be the best way to check and make sure everything is in order. thanks for the replies
Old Apr 10, 2003 | 12:55 AM
u do have a fuel pressure gauge right.....
i keep my eye at that like a hawk....
Old Apr 10, 2003 | 01:11 PM
yeah i have one in the pillar, but i just wanted to make sure everything was as good as it could get, i think it may be difficult to watch the fuel pressure guage while watching the tach and everything else
Old Apr 11, 2003 | 09:17 AM
Dave 96TA's Avatar
I've heard/read that 3-5psi below the WOT fuel psi is the 'safest', but could also disable the N2O with the slightest fluctuation.
Old Apr 11, 2003 | 09:44 AM
OffspringZ28's Avatar
hmmm
at idle my pressure is at like 33
at WOT its like 42
Old Apr 11, 2003 | 12:22 PM
craigffb's Avatar
Originally posted by OffspringZ28
hmmm
at WOT its like 42
That's right. The 43-45 PSI is the WOT reading. You can check what the WOT is if you pull the vacuum line off you fuel pressure regulator, but you probibly knew that.
Old Apr 11, 2003 | 12:44 PM
sideways_Into_3rd's Avatar
hmmmmmm
my idle is 41 my wot is 43 !! WTF ?
damnit .. now i need a new regulator... or maybe my vaccum line has a crack in it !? hmmmm
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
