what should i do before I spray 125 wet shot?
Old Dec 10, 2002 | 05:02 PM
stik6shift00's Avatar
I am putting a nx wet kit on around spring time, I know im going to need a stage 3 clutch, you can look at my mods, suggest anything else? I might save up for a 12 bolt also, think its worth it or go with a to a 8.8'' 10 bolt
Old Dec 10, 2002 | 07:09 PM
funina91ss's Avatar
I have 5sugestions
1 bigger fuel pump stock will work but to be safer get one
2 colder plugs around 2 heat ranges colder than stock
3 MSD 6AL or simular
4 12 bolt or 9"
5 SLICKS
Old Dec 11, 2002 | 12:19 PM
Toms30th's Avatar
You could go with a new fuel pump, but the cheaper way to go is a fuel pressure safety switch. I think you should also get a window switch.
Old Dec 11, 2002 | 06:35 PM
i have a msd window switch, i have msd wires..how much is a fuel pump, a pretty good one. And do you think a 8.8'' 10 bolt would be good enough or just get the 12
Old Dec 11, 2002 | 07:48 PM
LT1ponykilla's Avatar
Im sure you know this already but i have to say this. Do not forget the bottle warmer!!! I know people that have blown there motors spraying large shots without a warmer. It can do bad things to your car. Just a reminder.
Old Dec 11, 2002 | 08:12 PM
yeah, wont forget that, and all the extra safty things
Old Dec 11, 2002 | 08:35 PM
crazyjoe's Avatar
125 shot?
From what I understand, NX only offers a 100 shot or 150 shot, no 125. My NX chart doesnt have a jet listing for a 125 shot, I wish they did though. Anyhow, this is what I'm running in the '95:
150 shot (NX), Bottle warmer, Purge,
Wide Open Throttle switch
Fuel pressure safety switch
MSD-6AL ignition
Autolite 104 plugs
Walbro 255lph fuel pump
I believe that's about it, (Sean, chime in if I missed something ) No window switch and I spray out of the whole (stock rearend) and spray through shifts, however, I dont recommend it as it's a little rough on the stock tranny. Next year I hope to have a window switch to prolong the life of the transmission. We've run 3 bottles through it with no problems whatsoever (well, we have hit the rev limiter a few times, thank you MSD-6AL, engine saved!!!) But other than that, nothing has broke and the car is flying!! Check the sig for times. Good luck and happy spraying!!
Joe.
Old Dec 11, 2002 | 10:08 PM
stik6shift98's Avatar
get the ngk tr 6 plugs
fuel pump
get remote bottle opner
bottle heater
purge
blow down tube
bottle blanket
and then are cars will have the exact same setup.....
im preety sure there is a 125 shot....
Old Dec 11, 2002 | 10:21 PM
95 Mystic TA's Avatar
fuel pump
bottle heater
purge
blow down tube
bottle blanket
What exactly is a bottle blanket? The name kinda explains it but what kind of advantage does this give you over using just the bottle heater? I have the bottle heater on the way but I haven't seen to many people with a bottle blanket. Thanks for clearing up the confusion if you can.
Old Dec 12, 2002 | 12:51 PM
The bottle blanket is no more than what is sounds like. Just a cover for the bottle to keep from scratching it and to help warm it when the bottle heater is used.
Old Dec 12, 2002 | 05:36 PM
94z'sson's Avatar
hey
1.fuel pump
2.ngk tr6 plugs
3.window switch
but how about getting a 9inch if your going to put a 12 bolt in it
a 9 inch is so much easier to change gear ratios but just my 2 cents
good luck
1987 irocz
you will have to come to the strip to see what i got
pops 1994 z28
i am not allowed to say, but it aint bad for a lowered z28 with stock internals
Old Dec 14, 2002 | 10:01 PM
bottle blanket is preety much useless...jst looks cool...and protect my bottle just like ponykilla says......
Old Dec 14, 2002 | 10:19 PM
Guido67SS's Avatar
Nos
The ford 9 " is a good rear but no better than a 12 bolt. Unless you get an after market 9" that is built specifically built for your performance application.
I went with a Moser 12 bolt straight from Moser. I use a girdle cover. Bullet proof in a heavy car. My .02.
I've seen the corp 10 bolts with a girlde run 10's with slicks.
C- Clip elims are a must though.
Good Luck!
Guido
LT14LIFE
Nov 15, 2015 06:22 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
