wet shot using a polished intake
Old May 19, 2004 | 06:54 PM
limige's Avatar
i alittle concerned about running a large wet shot on my setup..
i have a monoblade with a ported and polished intake which has been filled in certain areas. shortly my heads will be ported and polished as well..
the lt1 intake was designed as a dry intake, my nx kit suggest installing the nozzle 6-8 inches prior to the tb.
now we have introduced fuel and nitrous prior to the tb and into the intake.
my concerns are proper distribution and atomization of the fuel and nitrous, the nozzle should atomize it good but i'm still somewhat concerned...
any thoughts on this issue?
Old May 19, 2004 | 07:16 PM
Loadre's Avatar
The nozzle should do all the atomizing that it will need.
Old May 19, 2004 | 10:12 PM
limige's Avatar
what about distribution though, has anyone pulled their motor apart to find some cylinders where different from others?
Old May 19, 2004 | 10:30 PM
RacinLT1's Avatar
when i pulled my engine apart i noticed no discernable patterns on the pistons.this was after 150-175 worth of nitrous over a few years.
Old May 19, 2004 | 11:10 PM
Fuels94TA's Avatar
That why NX say have it about 6 inchs away from the TB so that it will atomize properly.
Vinny
Old May 19, 2004 | 11:11 PM
Loadre's Avatar
Vinny
...and distribute properly.
Old May 21, 2004 | 11:36 AM
Will84's Avatar
Vinny
Does the plate mount system atomize properly? I'm going with a system from Nitrous Works... It's definately not 6 inches away from the TB. Would it be better to go with a nozzle system?
Old May 21, 2004 | 08:11 PM
Fuels94TA's Avatar
I'm not to familiar with nitrous work products. But a plate system is installed behind the TB, not 6 inches in front of the TB like a nozzle set up. I really never heard any serious negative comments about NW. The reason I like my NX system is it dyno what it put out to the rear wheels.
Vinny
Drtryder
Apr 22, 2015 04:17 PM
Noenav
Dec 6, 2014 07:35 PM
rje
Sep 9, 2002 12:35 PM
Teal94V-6
Aug 31, 2002 09:21 PM
