wet or dry nitrous system?
Old Oct 18, 2009 | 05:11 PM
SmokinZ28lt1's Avatar
Question wet or dry nitrous system?
I'm going to put a nitrous system on my 1994 camaro it has headers,exhaust, no cat, 58mm tb,and 36lb injectors and I was woundering if a wet or dry system would be better.....
Old Oct 18, 2009 | 05:25 PM
slowride94z's Avatar
I had dry but went to wet,
Old Oct 18, 2009 | 06:09 PM
94ltz's Avatar
I like the idea of wet like i have of my car cause you have a pre-mix before it enters the intake, instead of putting a big shock of just the nitrous into the system and hope the fuel catches up, thats just the way i look at it and if i'm wrong sorry..
Old Oct 18, 2009 | 06:13 PM
Actually, if you spike the fuel pressure (or run an aftermarket ECU that knows when the nitrous system is activated) at the same time you hit the spray, the fuel will not be "catching up".
I run a dry 300-shot.
This belongs in the N2O Tech forum. Moving.......
Old Oct 23, 2009 | 08:02 AM
rskrause's Avatar
Moderator
Generally I prefer "wet" as I think it's easier to tune.
Rich
Old Oct 23, 2009 | 09:32 PM
87Aerocoupe's Avatar
Do you guys prefer a nozzle, dual nozzles or a plate setup?
Old Nov 23, 2009 | 03:57 PM
slomarao's Avatar
I would go with n2o outlet's plate setup.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Omega9
Aug 17, 2002 04:23 PM
Omega9
Aug 14, 2002 10:59 PM
Omega9
Aug 14, 2002 07:55 PM
