Two stages and retarding the timing
Old Sep 2, 2007 | 01:28 PM
Z-RATED94's Avatar
I'm not even done hooking up the nitrous yet, and I'm thinking of running a two stage set-up. I'll be running the 685 ign. box with the Nitro Daves plate system. Maybe a 100 shot off the line. The car might be traction limited. Then how about another 50 once the car hits 2nd. Could something like a MSD retard box be wired in to the system to retard the timing another 2 degress or whatever it needs, once the 2nd stage kicks in? I was thinking a button on the steering wheel, to trigger the 2nd stage. Any draw backs to running two systems off of one bottle? Thanks, Rick.
Old Sep 2, 2007 | 10:51 PM
JodyJ's Avatar
Take a look at the MSD Digital Multi-Retard unit (http://www.msdignition.com/tc_6.htm) I'm thinking about running run of these or maybe the FJO Nitrous Mini-Controller (http://www.fjoracing.com/products/2stageminicontroller/)
I have both systems, but they are not yet tried them. I'm leaning towards the FJO because of the ability to progressively bring in the 200 shot that I will be running.
I think with the suspension setup you have you'll have no problem hooking up on the 150 shot.
Jody J.
Old Sep 3, 2007 | 12:29 PM
1982z28with18s's Avatar
You can retard the timing for the first stage via the IAT mod, and the 2nd with the box.
Old Sep 11, 2007 | 09:47 AM
97formulakid's Avatar
IAT mod??
Old Sep 11, 2007 | 11:07 AM
You trick the iat into thinking it's a high temp, then in the tune, you change those cells to pull how ever much timing you wish. Do a search on ls1tech and you should be able to find more info on it.
mikey4play
Mar 15, 2015 11:45 AM
cyteone
Feb 7, 2015 06:04 PM
importkiller94
Jan 17, 2015 09:03 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
