Trick Flow Dual Install
Old May 10, 2005 | 06:48 PM
pennys58's Avatar
Trick Flow NX Wet Kit Install
Was wondering if anyone had any pics or stories on installing a NX wet nozzle on the Trick Flow aluminum elbow. Not really sure if it's a lot of work or not or if it is worth it to try. Thanks.
John
Old May 10, 2005 | 10:31 PM
Nitro Dave's Avatar
Re: Trick Flow Dual Install
John,
NX makes a perfect kit for this.They offer a dual nozzle kit.Its real popular with the Viper guys.There isnt two much tow it.Just drill the holes and use the two peice nuts tow hold the nozzles.Or drill the holes and tap the elbow and screw the nozzles directly in.
Dave
Old May 11, 2005 | 04:52 PM
pennys58's Avatar
Re: Trick Flow NX Wet Kit Install
Dave,
I have the a NX wet kit with genx2 upgrade...is there a part that I can get for just the nozzle? I meant it was only one nozzle, but with the dual exit...sorry...wet. Thanks.
John
Old May 14, 2005 | 12:38 AM
funina91ss's Avatar
Originally Posted by pennys58
Dave,
John
You will have to get a fuel noid and a N20 noid too if you plan on running a dual stage.
Old May 14, 2005 | 11:47 AM
pennys58's Avatar
My bad, I meant how was the install of a single nozzle going into the trick flow metal exterior. How do you keep it secure with out it looking ghetto or having a leak? I am not wanting a dual set up...I meant a wet system.
Old May 14, 2005 | 02:00 PM
funina91ss's Avatar
I drilled and tapped my hole in the TF elbow.. It was real simple.
Pic
Old May 14, 2005 | 02:26 PM
pennys58's Avatar
That looks awesome. What did you use to seal the hole that you tapped.
Old May 14, 2005 | 06:44 PM
funina91ss's Avatar
I just threaded it in untill it was tight. No sealent needed.
Old May 15, 2005 | 07:33 AM
Derrick Redd's Avatar
I have mine installed the exact same way.
Old May 15, 2005 | 11:15 AM
Loadre's Avatar
Werd, except in a different position.
Old May 15, 2005 | 01:26 PM
Snakebyt's Avatar
this is how ours was set up, old pic of the motor before the supercharger install.
Old May 15, 2005 | 09:27 PM
pennys58's Avatar
After seeing those pics, I am definately getting the trick flow elbow. Funina91ss, how exactly did you get the nitrous set up like that in the back seat. That's what I am planning on doing...just have to get her up a little and then a buddy is fabbing a cover to hide it. Thanks!
John
Old May 15, 2005 | 10:10 PM
funina91ss's Avatar
I got my straps from a muffler shop they just gave them to me. they had short ones and long ones I put the short ones in the rear and long ones in the front to keep the bottle at an angle.bottle pics
Old May 16, 2005 | 07:08 PM
rpm4lalo's Avatar
I did dual nos fogger nozzles on my trick flow elbow. Drilled and tapped, I used some teflon tape, but they really didn't need it. The first stage is 100hp and the second is 125hp.
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MadMav
Feb 6, 2015 11:02 PM
Jan 23, 2015 01:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
