Fuel system for 200 direct port
Got kit in today, NOS Sportsman. I dont really want to go with a seperate fuel system at this point either. Would it be safe to fun the fuel for the system off the test valve? Or should I look into taking it somewhere to weld a fitting onto the rails?
Re: Fuel system for 200 direct port
I'm planning on going up to a 250 shot eventually, so I know thats the smart thing to do in the long run. But is using that valve, that bad? Would having the fuel rails tapped and running a seperate line from them to the noids be almost just as well?
The problem is that you are going to need a big fuel pump to support a direct port and motor.More than a intank standard pump will support.You can use our stand alone system and have all the fuel you could ever need.Here is a link.
http://www.nitrousoutlet.com/outlet/...section_id=122
Dave
Dave
CARiD
Jan 27, 2015 06:27 AM
Jul 4, 2005 05:00 PM
