Timing with spray
Old Mar 29, 2005 | 08:17 PM
Hybrid86Z's Avatar
Timing with spray
where all do you guys have your timing set at on the hose? I'm just curious what the base numbers i should have it set at (going to get dyno tuned for NA motor, then have a timing box for the spray to adj. the timing when I'm on the hose)
Your thoughts? I'll be spraying a 175-200 shot
-Ben
Old Mar 30, 2005 | 12:38 PM
NHRA's Avatar
Re: Timing with spray
Most nitrous companies reccommend 1.5 to 2* retard for every 50 HP nitrous used. So retard your timing about 8* for a 200 shot.
Klypto
Mar 23, 2016 09:05 AM
Fatdog2
Feb 13, 2015 08:19 PM
David Dorris
Jan 17, 2015 08:10 PM
tds1213
Nov 27, 2014 12:55 PM
