Timing question
Old Feb 2, 2009 | 09:47 AM
ShownomercyZ28's Avatar
Timing question
I just bought a nitrous outlet kit and was wondering how I should make sure I don't blow up my car. Its a heads/cam LT1 and I am running a MSD6Al right now with a big *** mallory coil. Question is, I have been reading that most people use the 685 or something instead of a 6AL? Would it be worth selling the MSD and picking up the other kind?
Also, I was wondering if I can spray before WOT as I rarely see that, its a DD. So this would be for the "track", wink wink. I understand not spraying below 3k but can I get a window switch and have it come on at 3k and just go until I let off or hit say 6k?
And, any ideas on hiding a plate? Its gonna be fairly obvious no?
Old Feb 3, 2009 | 04:57 PM
LSWHO's Avatar
How big of a shot are you wanting to use? If under 100 the general consensus is that it's not mandatory to pull timing. Over 100 then it's 2 degrees per 50hp.
I personally am getting the 685 for the window AND timing aspect. (150 shot planned)
What's the point of spraying if you aren't WOT?! That's a GREAT way to blow the motor.
Is your car a M6 or auto?
Old Feb 3, 2009 | 05:06 PM
Its an auto, and I wanna spray a 100 shot.
And technically WOT is 6200 but I just don't want to spin it that high.
Old Feb 3, 2009 | 05:14 PM
LSWHO's Avatar
What?
Do you have a stall? I have a 3200 and I plan on spraying from 4000-5800.
Old Feb 3, 2009 | 05:33 PM
Its a heads/cam with a 3200 stall.
Old Feb 4, 2009 | 09:32 AM
Z-RATED94's Avatar
WOT is WOT!! TB or carb blades all the way open. If your combo redlines at 6200 so be it. If you do run nitrous, you can lower your shift points some and lose very little if any performance.
Old Feb 4, 2009 | 12:18 PM
Ok, I guess 6200 it is. I guess I should start saving for a rebuild soon.
http://www.nitrousoutlet.com/catalog...product_id=964
Can I use this as a WOT switch and window?
Old Feb 4, 2009 | 05:29 PM
AutoRoc's Avatar
Originally Posted by LSWHO
What?
What a sad little window of fun time...
Old Feb 5, 2009 | 09:28 AM
Z-RATED94's Avatar
WOT yes, but I don't think it can pull timing. I'm using a Mallory 685 for that. Nitrous Outlet can set you up with that and anything else you might need.
If you do this right, it might be a while before you need a rebuild. So far mine is still in one piece. Almost 500rwhp on the stock bottom end.
Old Feb 5, 2009 | 09:50 AM
Thats the big hope, do it right and have it last.
Old Feb 6, 2009 | 08:39 AM
rskrause's Avatar
Moderator
Just have your PCM reprogrammed to take a couple of degrees out of the top of the timing table. You won't notice it off the spray and it will save some fooling around.
Rich
Feffman
Oct 9, 2015 05:42 AM
sscott
Jan 17, 2015 04:30 PM
capebuf
Jan 13, 2015 07:22 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
