thinking about N2O
Old Jan 23, 2008 | 07:07 AM
BC2002SS's Avatar
thinking about N2O
but for a 3800 SC, can't seem to get much good info. You would need a plate for under the SC or the under the injector nozzle as I was told you should not spray through the SC. Something about the coating on the rotors. thanks in advance for any help here is a pic of the motor.
Old Jan 23, 2008 | 09:14 AM
Ray@NitroDaves's Avatar
http://i107.photobucket.com/albums/m...Picture064.jpg
I would suggest any of the single nozzle systems....I have spoken with the Tech Depts of both Nitrous Express and NOS and neither have ever seen an issue with the rotors because of nitrous. We have countless customers spraying a wet shot on Eaton superchargers.
Our Brand X kit ($299) would be a good fit for you as I doubt you would ever spray more than 200hp worth of nitrous.
At this time I don't know of a single company that makes an under blower plate. If this was an issue there would be companies that would have them for the 03-04 cobra's and lightnings. NOS has a TB plate for them tho'
Please let me know if you have any other questions,
Ray
Old Jan 24, 2008 | 08:42 AM
BC2002SS's Avatar
what do you think of the under the injector nozzle like the NXL ?
Old Jan 24, 2008 | 08:56 AM
They are OK but results can vary depending on the application. The issue with this style nozzle, is they will pull a vaccuum on the injector. This can cause tuning issues especially on larger shots of nitrous. They might work for you depending on the size injectors you are running and the amount of nitrous you want to run.
Old Jan 24, 2008 | 09:12 AM
BC2002SS's Avatar
thanks for your answers on this
Old Jan 26, 2008 | 12:34 PM
2000GTP's Avatar
Very interesting setup. I was thinking about spraying my GTP there for awhile. Were you planning on spraying with the intent of adding extra power, or are you using it as a cooling charge and running more boost from the supercharger? Have you also looked into www.clubgp.com? I haven't been on there in ages, but I do know there were people who were doing nitrous setups on their supercharged engines.
Old Jan 26, 2008 | 09:11 PM
BC2002SS's Avatar
there and 3800pro just looking for around a 100 hp. car runs 13.0 looking for mid to low 12's
Old Jan 27, 2008 | 07:46 AM
2000GTP's Avatar
How hard is it to mount an intercooler in the Fiero 3800 SC platform? Do they make a kit for it or has it been done yet?
Old Jan 27, 2008 | 08:19 AM
BC2002SS's Avatar
most use some variation of the ZZP kit with different hoses run to the front of the car. Just got slowed down on this yesterday, broke off a break caliper on the passenger side front. will have to work that out before I move on to get faster.
Old Jan 27, 2008 | 10:08 AM
slowride94z's Avatar
nice fiero, IMPRESSIVE
the ss is hot but it is diffrent to see a fiero, nice ride man
kidd
Magenta_Hearts
Mar 22, 2015 03:36 PM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
kandied91z
Mar 3, 2015 11:34 AM
Jlo
Feb 3, 2015 09:41 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
