"T" fitting or something else?
Old Mar 18, 2005 | 12:53 PM
97Z-pimp's Avatar
Ok i have done lots of reading on this but i still have a question. I'm getting a wet kit with a fpss and an electronic fuel pressure gauge. comming off the schrader valve i will have a 90 degree fitting (NOS-17535), then a 2 foot -4AN to 1/8th NPT fitting hose(NOS-15230-2). Then a 1/8th "T" fitting with 3 female ends. I plan to have the fuel pressure sensor on one fitting and then i still have the fpss and solenoid to hook up. Can i connect the fpss to the "T" fitting and then have the solenoid in line after that? Or what should i do? Thanks
Old Mar 18, 2005 | 02:44 PM
BlownF1's Avatar
Re: "T" fitting or something else?
I have mine setup basically the way you describe. See the very first picture on this page? http://www.nitrousexpress.com/Pages/EFIAccess.htm
That's what NX supplies and the FPSS (as shown) attaches to it, and directly opposite (on the back side in the photo) is where I installed my electric fuel pressure sender. The fuel line goes in one end and the solenoid in the other. Didn't need anything additional...hope that helps.
Old Mar 18, 2005 | 02:58 PM
MEAN_SBC's Avatar
Yes, that will work like a champ...
Old Mar 18, 2005 | 04:23 PM
DrewHMS97SS's Avatar
i put my fp sensor in my aero afpr.
Old Mar 18, 2005 | 09:45 PM
97Z-pimp's Avatar
Ok so that part # is 15513 D-4, right? I just want to get this right...so the male end gets connected to the braided hose and that is 1/8th NPT right? Then on the two ports oppisite to one another have the fpss and fuel pressure sensor. Then on the female end gets connected to the fuel solenoid, but those are both feamle right? So would i need a double male fitting? Thanks again for the help guys.
Old Mar 21, 2005 | 01:00 PM
396D1SS's Avatar
speed inc sells a T that screws in the shrader valve with 2 exits
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
Jan 23, 2015 01:13 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
