Best match with the 6-AL
What window switch and retard matches best with the 6-AL? Is there anything that is plug and play with the 6-AL. Anything to make this install easier!! Thanks.
John
John
Re: Best match with the 6-AL
I do not believe there is a plug n play window switch for the 6AL... The installation of the window switch is very straight forward though... You just need access to the tach wire, and a power source.. The window switch just breaks the ground to your nitrous system relay.... It's really easy to wire....
Here's a typical window switch wiring diagram.
CARiD
Sep 30, 2015 05:44 AM
Sep 17, 2015 11:53 AM
