Switch Set-ups
Old Dec 14, 2004 | 01:32 PM
"White Knight"'s Avatar
Switch Set-ups
Where do you all have your switches mounted?? I am starting to get more and more switches. Fan switch, line lock, i'm wondering where i'll put all these switches if i get a nitrous kit.
Old Dec 14, 2004 | 05:29 PM
n2oCamaro's Avatar
Re: Switch Set-ups
I made a custom panel for the little storage area under the stereo. I used 1/16" aluminum. I am going to take some pics and put them up on my site sometime soon.
Old Dec 14, 2004 | 08:15 PM
Re: Switch Set-ups
That sounds pretty cool. Yea get some pics up and pm me when you do. I really was thinking about trying that. I kindof want to try to match the plastic, but i think it will be impossible. Next semester i have plastics i believe so i'll probably try in there. I remember someone made some once upon a time....don't know if it's true or what not. I know i was thinking of a panel that would flip around and lock into place so you could hide the nitrous gauges and switches in that cubby. I think it would be really hard to do. If some company would just make one
Old Dec 20, 2004 | 04:36 PM
6LITEREATER's Avatar
Re: Switch Set-ups
Most stereo shops carry that black plastic that matches.
When I had my 94 Z I bought a piece of the plastic, cut it square to fit the hole, mounted two gauges and switches in it and it looked just like the piece RK Sport used to sell.
To be stealth, you could tint your gauge (with window tint) really dark and then put a hyperwhite bulb in it and make it so that the bulb comes on when you arm the system. That would be sweet.
Old Dec 21, 2004 | 07:32 AM
Re: Switch Set-ups
That's a cool idea^
Do you know if i can get it online? I don't have any really good audio shops around me other than like circuit city, abc wherehouse, etc. It probably has to be a more custom place to get the plastic i would think maybe not though?
Old Dec 21, 2004 | 09:52 AM
fastcamz28's Avatar
Re: Switch Set-ups
I have the nitrous switches in the ashtray compartment, using the NX switches for activation/heater and bottle opener only. The line lock activation switch/lite are mounted on the cigarette lighter plate, and the line lock button and purge button are on the console; side and top respectively. I emailed you some pics showing my set-up. The 2 guages in the console CD space are A/F ratio and bottle pressure. Hope this helps!
Old Dec 22, 2004 | 08:42 AM
Zippity'Z's Avatar
Re: Switch Set-ups
You can see some custom one for the ashtray that are hidden here
http://www.jimmy-jams.com/ashtrayplates.htm
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
