Spraying through shifts?
Old Oct 26, 2004 | 03:55 PM
  #16
RacinLT1's Avatar
Re: Spraying through shifts?
find a good trans builder,and you wont be doing it every 1-2 years. mine went 2 years before the output shaft broke deep inside the trans. Frank (12SCNDZ) never saw anything like that,and he built me a hulluva trans.
Old Oct 26, 2004 | 04:45 PM
  #17
mrr23's Avatar
it's no different than shifting through the power of a NA motor making the same power. or a turbo or SC. do you let off in those instances? i spray through mine. done it on 5 cars. one th350, a 700r4, and 3 4l60e cars.
Old Oct 27, 2004 | 01:52 AM
  #18
scottslt1z28's Avatar
Originally Posted by Loadre
Shift at 57xx and change. Set the window switch to 5600. If you want to get real good at pulling a tranny in 30 minutes then start spraying through the shifts.
im confused.............what do you mean???? set it to 5700 or 5600...........where does everyone usually set their spray to cut off??
Sorry, Thanks
Scott
Old Oct 27, 2004 | 03:41 AM
  #19
dmoor88's Avatar
Originally Posted by Mike Comp T/A #57
I have been running nitrous since 1997 with no problems. I have always sprayed through the shifts. I thought everyone did. I have a stock 4L60E trans.
you spray through the shifts wih a stock a4 and cut 1.4 60's?
marlar98
Sep 19, 2015 07:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
CARiD
Sep 7, 2015 08:21 AM
War Engine
Aug 21, 2015 05:28 AM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
