is soem thing wrong???
Old Mar 8, 2003 | 12:58 AM
hitman8728's Avatar
hey guy si went to the track with my nbitrosu for my 1st time with the 100jets in my normal time was a 14.12 and toniught i was geting 13.7 at 104 does that seem right
Old Mar 8, 2003 | 06:18 AM
RacinLT1's Avatar
Were you spinning? What was the bottle pressure? was it detonating?
Old Mar 8, 2003 | 10:46 AM
hitman8728's Avatar
yeah my 60foot was a 2.2 could the be the problem?
Old Mar 8, 2003 | 03:32 PM
RacinLT1's Avatar
Yeah that would be a problem. If the 60' was in the 1.8's you woulda gone low 13's.
What was the 60' on the motor pass? what was bottle pressure?
Old Mar 8, 2003 | 04:50 PM
hitman8728's Avatar
im not sure what the bottle pressure was but i ran 4 runs and it only took 2lbs of nitrous that not right is it
Old Mar 9, 2003 | 09:54 PM
stik6shift98's Avatar
your bottle pressure was most likely low...do u have a bottle heater? do u have a press gauge??? u should defintly invest in the gauge and posibly in the heater
Old Mar 11, 2003 | 09:55 AM
95greendragon's Avatar
Yup it's the bottle pressure 104 MPH on a 100 shot is way low. I run a 100 shot and run 110-111 on street tires mostly stock (no drag radials.) The same thing happened to me, except my 104MPH was caused by a leaking fitting (bottle was mostly empty by the time I ran). A 2.2 60' is not great but think about this I run 12.80's with my 2.1 60'. You'll get it right, make sure the bottle is full and the pressure is right (900-1000 PSI this is VERY important get a gauge if the pressure is not right you will see bad things either sweeping up an engine or running slow times..)
timmy39120
May 2, 2015 05:12 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Hal Fisher
Sep 14, 2002 09:36 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
