small dry shot on a modded lt1
ok, according to the searches i have done, this is an effictive way to go faster, and ecoomical if you know where to get the stuff from. from what i have read, if you keep it under a 75 shot, spray through the maf (not directly on it though) and raise the fuel pressure a notch you should be ok. other than adding colder spark plugs have i missed anything? its either this or a gear for me this summer, just tring to make up my mind.
Re: small dry shot on a modded lt1
I like the wet kit as you can tune the jets (nitrous and fuel) to get a safe shot (dyno tuned with wideband O2) without messing up your standard tune (without nitrous). Run one heat range colder non-platinum plugs (Autolite 104's, NGK TR6's), a fuel pressure safety switch and a rpm window switch. I also like the bottle heater as you need proper nitrous pressure to get a consistent shot.
Originally Posted by roguedriver
You can't spray through the maf on a 95'. That will only work on LS's, not LT's. You'll have to put your nozzle post-MAF.
Ken R.
Ken R.
If you do this just make sure the nozzle is placed 6-8" prior to the MAF to keep from freezing it.
I didn't trust the Compucar kit for any higher HP. I'm am now going with an NX wet kit for 150 HP. And I actually recommend a wet kit and jet it for 75 HP if that's all you want. Should be very safe, even with stock plugs, fuel pump, timing, etc.
http://www.speedshop.org/store/scrip...?idproduct=110
Dean
Also, I recommend going with a kit that will allow you to up the shot safely. Rather than what I did and had to sell my Compucar kit to a Mustang racer and start over.
Lt1son
Dec 31, 2014 01:35 PM
