Show me some pics of your WOT nitrous setup.
Old Jun 18, 2005 | 05:50 PM
camz383's Avatar
I am trying to figure out a way to setup my WOT nitrous setup since mine isnt working like id like to. If you guys could just how me how you have yours set up to come on at WOT that would be great.
Zach
Old Jun 20, 2005 | 08:24 AM
whatsup's Avatar
Re: Show me some pics of your WOT nitrous setup.
http://www.cardomain.com/ride/948336
Click on bottom picture of motor. On the top drivers side of throttle body you will see the little white WOT switch. If you look real hard...on the back side of the switch you can see the little gold arm extruding out toward the driver fender. When WOT throttle happenes the cable holder on TB comes upward and trips the little arm. Seems to work good and easy access.
Old Jun 21, 2005 | 12:07 PM
camz383's Avatar
thanks, anyone else have some pics?
Old Jun 22, 2005 | 02:11 AM
Frans96SS's Avatar
i have mine mounted the same way
Old Jun 22, 2005 | 09:18 AM
BlownF1's Avatar
Skip the mechnical ones and do it right...get an electronic TPS one, no more worries.
Old Jun 22, 2005 | 11:18 AM
camz383's Avatar
hey blown, do you have a link to more info on what you are talking about?
Old Jun 22, 2005 | 02:39 PM
BlownF1's Avatar
There's several available, just do an internet search on "electronic TPS switch", etc. Here's Nitrous Expresses version:
http://www.nitrousexpress.com/Pages/TPS.htm
I've seen them much cheaper than that as well, perhaps someone else will provide a link to a better price. Try the usual vendors on the supporting vendor page.
Old Jun 23, 2005 | 01:59 PM
InsuranceGuy's Avatar
Here is the one that DynoTune sells.
http://www.dynotunenitrous.com/store...?idproduct=105
I do not endorse this product nor am I associated with DynoTune in
any way. Use at your own risk.
I have a really good closeup shot of my WOT bracket and I'll try
to post it later this evening. I had to do some fancy bending
but it fits perfectly.
Emil:93Z,383,Vortech,NOS
Old Jun 23, 2005 | 05:35 PM
camz383's Avatar
cool thanks bro, when ya get a chance post that pic of yours if you have time. Id like to see where everyone is triping theirs?
Old Jun 23, 2005 | 07:33 PM
This is a closeup of my WOT switch.
http://edusek.photosite.com/WOTswitch/
I had to bend the bracket and then used the bottom
TB bolt to hold it in place.
Emil:93Z,383,Vortech,NOS,Moser9",TH-350
Old Jun 23, 2005 | 11:14 PM
Zippity'Z's Avatar
Here's all you could want right here- custom made for your car
http://jimmy-jams.tripod.com/activationswitch.htm
Old Jun 26, 2005 | 02:32 PM
Joe Brodman's Avatar
GP Moderator
I don't have a pic of mine, but it's simple and easy.
Took my NX WOT switch, using small (but good) zip ties, tied it to throttle linkage under the black cover. As the car goes WOT, the WOT switch presses against the black cover. Has worked great for years; only real trick is to get it lined up right the first time, and make sure the wires sit firmly on the switch. Far cheaper than a TPS switch, and hasn't let me down.
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
BM93Z
Aug 22, 2002 02:45 PM
