Safe shot of nitrous?
Old Apr 3, 2006 | 11:16 AM
  #16
Moshbmx1's Avatar
Re: Safe shot of nitrous?
do yourself a favor and get a Mallory 685 box. It has window switch, retard and better spark all in one box. Also you might want to pick up a purge and blow down tube.
Thanks for the info on the 685, thats the way i will most likely go.
Old Apr 3, 2006 | 11:18 AM
  #17
Moshbmx1's Avatar
Originally Posted by Built LT1
I have done 175 wet to a stock LT1 without any problems. But I may be an exception to the trend. Go wet and go 150 max. Make sure your properly tuned for it and you should have no problems.
How much tuning did you have to do?
Old Apr 3, 2006 | 04:35 PM
  #18
bt96ss's Avatar
You should be able to pull enough timing out with the Mallory box to run 175 shot or better.
Old Apr 4, 2006 | 12:57 AM
  #19
Built LT1's Avatar
None, I ran two steps colder $1.99 non-platinum autolites with 100 octane unleaded. My computer was stock. I also changed my fuel filter frequently.
Results:
'93 Corvette with A4 with stock 3.07 gears.
13.75 @102 in motor; Dyno 235/262 rear wheel horse/torque
12.34 @117 on N2O-175 shot NX "Shark" nozzle; Dyno 375/487 ""
Old Apr 4, 2006 | 01:01 AM
  #20
Moshbmx1's Avatar
Results:
Very respectable results. I hope to be around there with the addition of a PCM tune
Old Apr 4, 2006 | 01:02 AM
  #21
Moshbmx1's Avatar
How much timing is needed to retard per amount of shot im running?
Old Apr 5, 2006 | 11:08 AM
  #22
Moshbmx1's Avatar
Alrite heres what im going with
HSW wet kit(Includes pressure gauge)
Heater
Purge
FPSS
Mallory 685
Autloite or NGK plugs (Should i change wires too??)
Then a tune from pcmsforless.com
Then also buyin Moroso CAI, bigger TB and 3.73 motive gears
Thanks for all your help and input it really helped.
If i forgot anything please let me know
Old Apr 7, 2006 | 09:49 AM
  #23
Joe B's Avatar
2 degrees retard "per" 50HP is a pretty safe start........you can always pull a bit less out after you see how it's running, and how your plugs look.......
Old Apr 7, 2006 | 09:57 AM
  #24
Joe B's Avatar
Heater
Purge
FPSS
Mallory 685
I would go with new wires... 40 bucks or so, is a small price to pay to know you don't have a wire that's going bad...ya know another reason is a new hotter than stock ignition like your getting can make a bad wire come to the surface even faster.....the MSD 8.5's are a good choice.....Also very important, Make sure when you talk to bryan from PCM's for less he "understands" you have an ignition box to handle your revlimiter, and that it has the capability of retarding your timing for the nitrous, that way he dosn't by mistake give you a conservative nitrous type tune more for someone with the stock ignition and revlimiter........This way he can move your stock (fuel cutting) revlimiter way up out of the way to around 7200 and give you a good naturally asperated tune, so you will have the best of both(just double check where he set your TOTAL timing at (mines at 38deg) so you'll know how much to pull on the bottle).....this is the EXACT way mine is set up from him and it runs great on and off the bottle....good luck
Old Apr 7, 2006 | 04:50 PM
  #25
Moshbmx1's Avatar
Thanks Joe. I also heard that wires were a beast to install...true?
Old Apr 8, 2006 | 07:53 PM
  #26
Moshbmx1's Avatar
Just ordered the kit today (4-8) from HarrisSpeedWorks. Thanks for all your help again guys
Old Apr 9, 2006 | 10:46 AM
  #27
Joe B's Avatar
........Yea, the drivers side sucks pretty bad(on the opti side)..........don't forget to use some dielectric greese on each internal connector on your new wires...and a little on the inside of each inner boot.....this will eliminate corrosion from ever building and give a water tight seal ,especially where you want it(on the opti-spark side)........it will also make it easier to hear and feel the "click" when you push your wires on the "sometimes" hard to hear or feel opti-spark side........
Old Apr 10, 2006 | 10:59 AM
  #28
Moshbmx1's Avatar
Ordered the Mallory 685 (4-9)
Got MSD Wires and NGK plugs (4-10)
Also got the msd harness (8876) to use with the 685
Big thanks to Joe B for walking me through this plug and wire deal
68camaroboltz
Oct 5, 2015 11:56 PM
95blkss
Sep 22, 2015 03:18 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
rideordie
Sep 7, 2015 08:22 AM
