Safe to install with full bottle?
Old Dec 19, 2006 | 10:26 PM
69gto96z's Avatar
Is it safe to install a nitrous kit with a full bottle? Or should I wait until I have it installed to fill it?
Old Dec 20, 2006 | 12:30 AM
LT-x7's Avatar
Well it won't give you much power if it's empty.
Just make sure you install the blowdown tube fitting on the back of the bottle before you fill it.
Old Dec 20, 2006 | 07:19 AM
69gto96z's Avatar
HAHAHAHA yeah thats true. I am glad you told me that or I wouldn't have done it.
Old Dec 20, 2006 | 09:35 AM
2000GTP's Avatar
It won't hurt anything, it may even come in handy when you are doing some of the plumbing. It says clearly in the instructions that before you hook up the main nitrous line to the solenoid, it is a good idea to crack open the valve a bit and blow out anything that may be sitting in the lines to prevent that debris from jamming up the nitrous solenoid. Also, when you do have everything hooked up completely, once again, you can open the bottle and check the entire car for any nitrous leaks.
Old Dec 20, 2006 | 10:36 PM
1SlowFormula's Avatar
I agree it is probably easier to have a full bottle or at least some in there during the install. When I did my first install I got some carpet fibers in the line when fishing it to the front of the car under the carpet, and had to get a shot of nitrogen from my neighbor, an HVAC repair guy, to get it out before hooking everything up...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Feffman
Oct 9, 2015 05:42 AM
Jan 23, 2015 01:13 PM
bandit383lt4
Dec 21, 2014 09:12 PM
