ring gap?
Old Sep 19, 2003 | 05:47 PM
dkeers's Avatar
ring gap?
I am assembling my lt1 (355) for my 95 z28. I am going to run the NOS sportsman fogger direct port kit (100-300hp) on it. I am setting up a dedicated fuel system to run at carb pressures. I have a set of speed pro, forged pistons (.030 over) and their moly coated ductile iron top ring. The car is a daily driver and it will see mild street/track N2O use (probably very rarely on the street and I don't go to the track too often). What do I need to set my ring gap at. The rings are file to fit.
Thanks a ton
Dustin
Old Sep 19, 2003 | 08:07 PM
gb95zconv's Avatar
If you gonna run more than a 200 shot I would say .024-.026 on top and bottom.
Old Sep 20, 2003 | 02:39 AM
dkeers's Avatar
I want to be able to spray a 200 - 250 shot and I don't like the idea of spraying it through the manifold. I had a TNT wet kit (very nice BTW) on my LS1 car (that I sold) and every time I sprayed it, I was worried that I was about to send the intake through the hood. I probably shouldn't worry so much. Anyway, the motor is apart right now and drilling and tapping the intake manifold is no problem and the sportsman fogger kit costs about the same that my TNT wet kit did (~$650). The fuel system will cost more but not too much more than the upgrades my stock fuel system would need to run a wet kit anyway.
Dustin
Old Sep 20, 2003 | 11:25 PM
dkeers's Avatar
Mild meaning how often it is used. I try to use in moderation .
magman
Apr 15, 2016 03:08 AM
Quickss96
Jan 29, 2016 05:56 PM
IndyZman
Oct 22, 2015 02:17 PM
mmf_1013
Sep 12, 2015 08:56 PM
blaze309
Sep 8, 2015 05:27 PM
