Question about perging w/out perge system!
Old Dec 13, 2002 | 04:40 PM
  #16
COMNBYU's Avatar
Originally posted by gb95zconv
Yes and no. Yes you will be rich till the N2O catches up .......if you'r to rich your engine may stumble which could lead to a backfire IF you dont have a window switch to shut the system down.
And it is fuel that will puddle not N2O(its a gas when not under pressure).
FINALLY, somebody with some brains.
Old Dec 13, 2002 | 06:19 PM
  #17
KTamez's Avatar
Guys in the end, there are a couple of preffered ways of going about this.
#1 being a tried and true Purge system
#2 being a momentary push button, and reving the engine to 3000-3500rpms, and doing a couple short bursts into the engine.
Lets just put this one to bed, and leave it at that the safest route is to buy a Solenoid, and adapt it in as a purge. ANY nitrous solenoid will, work though the "Purge Kits" also add the easy of adaptation.
Good luck!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Omega9
Aug 14, 2002 10:59 PM
