Running out of N2O while spraying
Old Dec 11, 2002 | 08:06 PM
z2894convertible's Avatar
Will this hurt anything?
Old Dec 11, 2002 | 08:28 PM
drop top steve's Avatar
You'll go super rich and the car well lay down, but no damage to the car.
Old Dec 11, 2002 | 09:58 PM
NXz28's Avatar
depends if its a wet or dry system.....if its wet then yeah...as said in the above reply...if it's dry...then your car will just slow donw b/c its not on the juice...but still no damage to car
Old Dec 12, 2002 | 04:25 PM
red's Avatar
red
In both wet and dry you will go rich. You will see no damage except for the car falling on it's face and black smoke in the exhaust.
Old Dec 12, 2002 | 10:16 PM
funina91ss's Avatar
Re: Running out of N2O while spraying
how much of a drop?Is it do to low bottle pressure or low on N20? you wont hurnt anything on either wet or dry wet will still flow the same amount of fuel as if the N20 was flowing right..
Old Dec 12, 2002 | 11:02 PM
chesee48's Avatar
this is a good topic...i guess i never once thought about it...
hmm....should just hook up 2 bottles just in case
Old Dec 13, 2002 | 09:36 PM
Z28ROC's Avatar
Just make sure you have enough nitrous before you race. Or have a backup bottle. I personally have 40lbs of nitrous at all times.
Fatdog2
Feb 13, 2015 08:19 PM
Jlo
Feb 3, 2015 09:41 PM
David Dorris
Jan 17, 2015 08:10 PM
taner
Jul 27, 2002 06:10 PM
