Presssure Controlled Bottle Heaters
Old Dec 5, 2004 | 10:15 AM
  #16
HeavyChevySS's Avatar
Re: Presssure Controlled Bottle Heaters
Originally Posted by sniffin94
I just wired my heater to a switch and watch the gauge. I don't know if the new automatic ones are the smae but the ones I saw shut off at 950 psi. I like to spray at 1100
Hey bud, the heater kit I purchased from Cold Fusion is set for 1100 psi.
Do you have the jetting chart when spraying at this pressure?
thanks, Heavy
Old Dec 5, 2004 | 11:29 AM
  #17
Dean77's Avatar
The dynotune pressure switch is adjustable - it can be set anywhere between 500 and 1250 PSI. Gives you the option of what pressure to spray at. Not sure about the cold fusion one but it may be the same.
Dean
Old Dec 6, 2004 | 09:04 PM
  #18
thanks, I'll check into it when I install it.
Quickss96
Jan 29, 2016 05:56 PM
Pwilson59
Sep 3, 2015 08:47 PM
weedog
Aug 15, 2015 08:23 PM
Henson071
Aug 4, 2015 09:32 AM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
