nozzle on top?
Old Feb 21, 2005 | 06:25 AM
whatsup's Avatar
nozzle on top?
I have a trick flow elbow. Will the shark nozzle fit on top of elbow after bend...and clear the hood?
Old Feb 21, 2005 | 01:35 PM
LT4383's Avatar
Re: nozzle on top?
Yeah, I simply drilled and tapped the elbow right in the middle of it so the nozzle screws in there perfectly.
Old Feb 21, 2005 | 10:13 PM
MEAN_SBC's Avatar
Re: nozzle on top?
It should fit..... The only problem you may run into is bending the lines sharp enough to clear the hood. Just make sure that after you bend them, they don't restrict flow in any way....
Old Feb 22, 2005 | 02:02 PM
91RSLT1's Avatar
Re: nozzle on top?
I was thinking of doing the exact same thing. My noids are mounted on the pass side on the STB. My only concern was bending the lines too sharply, so I was looking for two 90degree bend fittings, to connect the shark nozzle and the -3AN feed line. Anyone know any part number for such a fitting, or even who to contact? NX Ricky?
Old Feb 22, 2005 | 05:11 PM
whatsup's Avatar
Re: nozzle on top?
posted by Injuneer in another post: The only thing I would add is that you first put an NOS #17535 -4AN 90deg swivel fitting on the Schrader connection, then attach your fuel hose to that. Gets the connection pointed away from the cowl, and the "swivel" feature allows you to aim the connection anywhere you want, while still being able to tighten the fitting to the Schrader correctly, and not excessively tight.
I was thinking about doing this on the shark end also.
Old Feb 22, 2005 | 06:19 PM
91RSLT1's Avatar
Re: nozzle on top?
I already have that exact fitting on the schrader, but the nozzle needs the -3AN 90deg. Anyone have that part number?
Boss002
Jul 24, 2015 10:47 AM
hcarrickz3
Jul 21, 2015 08:46 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
Latronaxe
Jul 17, 2015 11:55 AM
Catmaigne
Jul 14, 2015 05:17 PM
