Nossle or plate LT1
Old Mar 4, 2007 | 12:15 AM
z2894droptop's Avatar
Nossle or plate LT1
What is the difference and which is better?
Old Mar 4, 2007 | 10:02 AM
How much do you plan to spray? NOSzles are direct port, for large shots.
Old Mar 4, 2007 | 07:33 PM
200 shot
Old Mar 4, 2007 | 07:48 PM
danhr's Avatar
the plate from nitrous works is crap... I'm in the process of converting mine to a nozzle.....and getting this damn dis-4 to work with my delteq...
there is a plate from a supporting vendor (it's one of two... and I dont want to say the wrong one). It looks very promising
Old Mar 4, 2007 | 09:12 PM
Loadre's Avatar
The nitrous outlet is re-releasing their LT1 plate. Look in the nitrous section of LS1 Tech
Old Mar 5, 2007 | 09:17 AM
Ray@NitroDaves's Avatar
it is posted here also
http://web.camaross.com/forums/showthread.php?t=505125
Old Mar 5, 2007 | 09:25 AM
A nozzle kit will mount the nozzle into the intake elbow/bellows in front of the throttle body (TB) and spray towards the TB, A plate will mount behind the TB and ours spray accross the airflow path such that the natural induction of the intake draws the mixture into the manifold.
Our plate has 8 distribution points, instead of one. This will help distribution slightly and a plate will also give you a cleaner install.
200 shot
This is the max we reccomend going to on the LT1 intake without going to a direct port. This is due to the flow characteristics of the LT1 style manifold.
pics of our plate can be found here...
Old Mar 5, 2007 | 12:20 PM
Rereading this, are you asking about a "nozzle", or a "NOSzle" system? They are two different things, and I may have misinterpreted your "nossle" misspelling.
Old Mar 6, 2007 | 03:31 PM
Sorry, I meant nozzle
Old Mar 6, 2007 | 04:09 PM
2000GTP's Avatar
Both systems can get you to your goals, the nozzle setup will be substantially cheaper though.
Old Mar 8, 2007 | 10:04 PM
95z28_m6's Avatar
http://web.camaross.com/forums/showthread.php?t=505125[/QUOTE]
Man that is one trick part.
Old Mar 9, 2007 | 09:19 AM
and it works as good as it looks
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Chet1185
Feb 4, 2015 09:51 PM
ddr698
Jan 9, 2015 10:05 AM
heavenly_six
Dec 10, 2014 12:23 AM
