Best cam for 396
Best cam for 396
What is the Best cam for 396, fully forged looking at a 200 shot or so. Its a M6 car with a 4.33 so the bigger the better, was just curious as to what was the best one out there or is there a good off the shelf cam for the set up?? I am currently running a CC306 on a 112 with the stock cubes, the heads flow great and have large valves so flow isnt a problem.
to get the most out of your setup is going to take a custom grind.....as far as cost most are comparably priced to shelf cams.
Brett Baur
Comp
Futral Motorsports
Cam Motion
plus many others can do it for you.
That way the stick can be spec'd to your use for the car.
Brett Baur
Comp
Futral Motorsports
Cam Motion
JasonD
Jul 27, 2002 08:57 PM
