nos question
Old Apr 30, 2008 | 06:52 PM
YoungCompton's Avatar
nos question
a friend of mine is planning on giving his STOCK 94 auto lt1 a 200 shot but i told him he would most likely mess something up, so he asked me what he would need to do to feed his car a 200 shot without messing anything up. Im no nos expert nor am i even using nos so i am asking you all what he needs?
o yeah and the local car clubs race (drag) every sunday knowing him he weill be 2 if he gets nos in his car, is there anything extra i should tell him for using it that often?
Old Apr 30, 2008 | 08:38 PM
northdakota93z28's Avatar
i would like to try a 200 shot on a stock lt1.
wet kit, colder plugs, good fuel, hit it above 3000 rpm.
tell what happens!!!
Old Apr 30, 2008 | 09:41 PM
Sparkz28ss's Avatar
get a broom..... and follow him around...someone is going to have to clean up that mess
Old May 1, 2008 | 06:32 AM
2000GTP's Avatar
I would say it is very risky. On a stock engine, I would probably go to a 150 shot tops. Assuming he has good fuel supply, pulled the necessary timing, and is spraying in a good rpm range, and this is being done on a healthy motor, he might be able to pull it off.
Old May 1, 2008 | 03:10 PM
well i thought he had no chance in hell it looks like he might have a ich of a chance lol (not worth it ot me) What would he have to do to his maro for it to take a 200 shot with NO PROBLEMS?
Old May 2, 2008 | 06:53 AM
2000GTP's Avatar
He would have to make sure his fuel pump can keep up with the demand in which case a higher output pump might be needed such as a Walbro or Racetronix piece. Also, he would have to pull the necessary amount of timing whether it be through PCM tuning, a Mallory 685 ignition box, or an MSD setup. A window switch is a good idea as well so he only sprays in a specific rpm range, the window switch is another built in feature of the Mallory 685 box. This is still very risky on a stock motor with an unknown history and there is absolutely no guarantee that he will be able to consistently and reliably spray a 200 shot. I would still encourage him to step it down a notch. That is how alot of people do damage to their engines and nitrous gets such a bad rep, people get greedy with the jetting and keep pushing the boundaries.
Old May 2, 2008 | 08:49 AM
Moshbmx1's Avatar
Have people sprayed 200 hp shots on stock LT1's and been fine for awhile yes, did it last very many hits...doubtful. IMO start out with a 125 hp shot and step it up to 150 hp if he absolutely wants too. Going 200 hp right off the bat is suicide. Make sure the motor is strong enough to handle the 125 shot first. Also, follow what 2000gtp said and look into the mallory and what all it has to offer as you will be needing to buy all of the safety accessories that go along with nitrous.
Old May 2, 2008 | 10:27 AM
i know there is a guy running 10.8 with a stock lt1 on nitrous i dont know what shot he run but it must be big. he is on the sight some place.
Old May 2, 2008 | 11:22 AM
2000GTP's Avatar
Its hard to assume that he is running a big shot. He could have other things going on with the car such as massive weight reduction or a very well dialed in suspension/drivetrain setup.
Old May 2, 2008 | 06:24 PM
ok thanks im gonna love rubbing the fact that i was right that he would most likely blow his engine up that way LOL
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
kandied91z
Aug 4, 2002 02:53 AM
FilledWithFurySS
Jul 26, 2002 02:00 PM
