NOS Opener
Old Apr 7, 2004 | 05:46 PM
TOZ's Avatar
TOZ
NOS Opener
Do this electronic Bottle openers seal the bottle pretty good ?
Old Apr 16, 2004 | 01:38 AM
Lt1tko5o's Avatar
The NOS electric openers are nothing but a NOS solenoid. They work pretty well but won't flow much more than a 175 shot. If you spraying less than that, it will work fine. As far as sealing, they will last as long and seal as well as a normal NOS solenoid.
Brian
Old Apr 16, 2004 | 10:34 AM
The NOS bottle opener seems to be more than a normal nitrous solenoid. Maybe its just the lack of a "return" spring, but the operation is completely different than a normal nitrous solenoid, which only activates when +12V power is constantly applied. The NOS bottle solenoid uses only a momentary +12V contact to move the inside cylinder to an open or closed position. Power is not applied constantly.
And I have sprayed 300flywheelHP through an NOS remote bottle valve, bolted directly to the bottle, and flowing directly into an NX porous bronze nitrous filter and a -6AN line.
The NOS valve seemed to seal fairly well. But I made it a habit to shut the hand valve when the car wasn't being driven.
NewsBot
Sep 30, 2015 04:20 PM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
