NoS?
Old Mar 20, 2008 | 12:57 AM
ZPower_123's Avatar
NoS?
How long does it take to burn out pistions with a 75 dry shot on my set up?
I would use the nos eveytime I drive the car 3-4 times a week for a few hours at a time
Old Mar 20, 2008 | 08:38 AM
2000GTP's Avatar
A 75 shot should be a pretty safe sized shot to spray. I would be more worried about constant bottle fill ups as nitrous cost per pound isn't exactly cheap.
Old Mar 20, 2008 | 02:12 PM
You don't "burn out" the pistons with nitrous as long as it is tuned correctly. If you run it lean it will detonate, and fracture the stock hypereutectic pistons.
Old Mar 23, 2008 | 11:59 PM
ZPower_123's Avatar
How much am i looking at for the full setup?
Old Mar 24, 2008 | 07:24 AM
2000GTP's Avatar
A setup with all the bells and whistles can easily tally you over a thousand bucks. I would like to say I have around 1250 in mine, the cost will escalate soon as I plan on changing some stuff and going from a nozzle to a plate setup.
Old Mar 24, 2008 | 06:58 PM
ZPower_123's Avatar
Whats the point of a purge?
Old Mar 24, 2008 | 07:08 PM
2000GTP's Avatar
The purge solenoid removes the air from the main nitrous line. Otherwise, with air in the line, the fuel will hit before the nitrous causing the engine to go rich upon the initial hit and bog the engine.
RUENUF
Mar 13, 2016 03:39 PM
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
cardemo16
Aug 24, 2015 01:04 AM
colts0455
Jul 20, 2015 09:52 AM
