nitrous pressure gauge sensor wiring question
Old 05-27-2013, 09:05 AM
97superchgedz28's Avatar
So I'm installing a glowshift pressure gauge on my dash, and the sensor fitting is similar to my pressure bottle warmer. The pressure sensor for my bottle warmer is under my hood, can I tap the wires into that for my pressure gauge so I don't have to tap in another line connector for my gauge sensor?
97superchgedz28 is offline
Old 05-27-2013, 10:03 AM
Re: nitrous pressure gauge sensor wiring question
Most pressure sensors are variable resistance based devices. If you connect them to two circuits in parallel, it will screw up the readings.
Injuneer is online now
bandit383lt4
12-21-2014 09:12 PM
brentbrowning01
12-16-2014 06:35 AM
Brandon Wittmer
12-03-2014 09:28 PM
Lt1son
N2O Tech
11-25-2014 01:52 PM
07-04-2005 05:00 PM
Quick Reply: nitrous pressure gauge sensor wiring question
