nitrous plugs
Old Apr 15, 2004 | 09:48 AM
slp223's Avatar
nitrous plugs
I am looking to spray a 200 shot with a dedicated fuel system. right now i am running ngk tr6 plugs (one heat range colder) for a 200 shot should i go two ranges colder like an autolite 103. does ngk make a colder plug then the tr6?
Old Apr 15, 2004 | 10:30 AM
Derrick Redd's Avatar
I'm running a NX 175 shot with Autolite 103's. Runs great on and off the bottle.
Old Apr 15, 2004 | 02:45 PM
94Zpower's Avatar
103's over hear also.
Old Apr 16, 2004 | 01:24 AM
Lt1tko5o's Avatar
I've heard alot of bad things with the NGK plugs, I've ran NOS for over 8 years now and I've always ran Autolight 104's (2 ranges cooler) and have never had a NOS problem. The only bad thing with too cold of a plug is a loss of power when running NA.
Brian
Old Apr 16, 2004 | 09:18 AM
speedmiser's Avatar
NGK TR7 is the same heat range as the autolite 103. NGK number goes up for a colder range - Autolite number goes down for a colder heat range
While I'm currently running the 103,(auto store was out of stock on NGK), I've ran the NGKs over the past 6 years without a problem.
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
Mar 13, 2016 03:39 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
bandit383lt4
Dec 21, 2014 09:12 PM
