nitrous plugs
nitrous plugs
I am looking to spray a 200 shot with a dedicated fuel system. right now i am running ngk tr6 plugs (one heat range colder) for a 200 shot should i go two ranges colder like an autolite 103. does ngk make a colder plug then the tr6?
I've heard alot of bad things with the NGK plugs, I've ran NOS for over 8 years now and I've always ran Autolight 104's (2 ranges cooler) and have never had a NOS problem. The only bad thing with too cold of a plug is a loss of power when running NA.
Brian
Brian
NGK TR7 is the same heat range as the autolite 103. NGK number goes up for a colder range - Autolite number goes down for a colder heat range
While I'm currently running the 103,(auto store was out of stock on NGK), I've ran the NGKs over the past 6 years without a problem.
FMFRacing88
May 25, 2015 08:08 PM
