Nitrous plate and aftermarket throttlebody
Old Jul 23, 2002 | 02:18 AM
Flames-N-Fury's Avatar
Angry Nitrous plate and aftermarket throttlebody
Whats up fellas? I put a compucar plate kit on my car about 2yrs ago. And I had to file down the back of the thromostat housing and it fit no problem. Then I went to put my 52mm on and I had to grind the s@#t out of the housing and the the housing under the throttle body witch is very thin and I ground through it F@#K. But any way after junking the gaskets and about a hundred cuse words I got it on. Any one go through the same problem?
96 Trans Am
Big Block Hood,Chrome Illusion Flames on
Black with ice pearl,Torque Thrust2 17x11 315/35/17rear 17x9.5 245/40/17front K&N cold air, Flowmaster cat back, Yank 3.0 coverter(2800)Lakewood LCA's and Panhard,1.8 drop,G2 saftey loop, 52mm throttle body MSD,and a Compucar kit.
Best ET 12.106@112.6mph
1.77 60 foot. 150 shot
Old Jul 24, 2002 | 09:29 AM
drop top steve's Avatar
Post
Aftermarket parts=hammer to fit, paint to hide.
Old Jul 24, 2002 | 12:10 PM
Andrew Duke's Avatar
Post
A Rubber Mallet was my choice to beat it in to place. Works great!
93 Trans Am a4, g2 intake w/k&n filter, holley 52mm tb, fan switches, bbk headers, no cat, flowmaster cat back, 125 shot w/compucar wet plate, zz9 cam, 3 angle valve job on heads, ET Streets for the track! Best ET w/potenza tires, 100 shot, and hypertech chip..
60' 1.763
12.112 @ 113.16
Old Jul 25, 2002 | 08:35 AM
speedmiser's Avatar
Post
I ran an MTI 52MM TB (stock bored TB) for awhile with a Compucar plate. I had no fitting problems whatsoever.
If I'm playin, I'm sprayin
93 Z28 A3 - w/ Jet Hot coated Hooker LT's and true 3" duals
(hiflow cats, cutouts, and Car Chemistry insert mufflers)
Old Jul 25, 2002 | 01:56 PM
Post
Yeah the aftermarket TB's are alittle longer.But a stock one bored out was going to be my plan B.
HibachiZ28
Nov 6, 2015 12:53 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
TGGodfrey
Aug 17, 2015 08:43 PM
karpetcm
Aug 14, 2015 03:02 PM
4586
Aug 13, 2015 10:11 PM
