Nitrous and Manual Transmissions...
Is there anything special I need to do when running nitrous on a manual trannsmission car? Besides a window switch and full throttle activation switch, I've heard some people saying you need anohter safety switch on the clutch pedal.
Just curious what you N20 guys with 5 or 6-speeds are doing. Thanks alot.
Nick
Nick
Re: Nitrous and Manual Transmissions...
You wont need a switch for the clutch since you'll have a WOT switch. If you let off the gas between the gears like a normal person would, you'll have no need for it. But for someone like me who likes to powershift without letting off the gas, I use a button.
Originally Posted by AllGoNoShow
Does anyone actually use nitrous on a manual? If you could tell me your set-up it would be appreciated?
I used a 225 shot on my car last year with the M6. I had a window switch, micro on the tb, FP safety and heavy duty MSD relay. I did not use an activation button. I let the Window switch turn it on and off. It worked flawless. Bear in mind my 396 was built for spray but even so there were no hiccups. I lift on the 1-2 but not on the others. 1-2 was too violent and would blow the tires off (relatively small slicks).
This year the DFI Gen 7 controls all the nitrous functions but I still kept the FP safety.
BTW, they're right above, save for a good clutch/rear. M6 cars are hard on driveline components. Ask me how I know......
Originally Posted by whatsup
How does that work? How does it know when you are in first gear?
RUENUF
Mar 13, 2016 03:37 PM
cmsmith
Sep 14, 2015 09:25 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
