nitrous lt1s come in please
Old Mar 1, 2007 | 02:50 PM
redington's Avatar
mods please dont move
guys i plan on doint a nx wet 100 shot. I am going to run a window switch and wot switch. I plan on getting a better fuel pump. My question is what else do i need to do to run safely on the lt1 motor. Mods are in sig. My miles are 70k on a 93.
Old Mar 1, 2007 | 02:52 PM
2000GTP's Avatar
One step colder, copper conductor plugs are another good bet. Depending how high you go down the road, a means of retarding the timing wouldn't be a bad idea either. With the Mallory 685 ignition box, there is both a built-in window switch and timing retard function. Also, a fuel pressure safety switch is a very important piece to add as well. Some other things to consider down the road would be a bottle heater, blowdown tube to stay track legal, and a purge valve. You might want to check the "sticky" in the nitrous forum, it goes over all this good stuff.
Old Mar 1, 2007 | 02:55 PM
redington's Avatar
thanks i didnt know if there was anything specific to the lt1s or not
- Mike
Old Mar 1, 2007 | 02:59 PM
2000GTP's Avatar
Whatever platform you have, whether it be LT1, LS1, or something else, the safety basics are generally the same: fuel pressure safety switch, colder plugs, window switch, WOT switch, ect.
Old Mar 1, 2007 | 04:21 PM
Why shouldn't it be moved? Nitrous is covered on the "N2O Tech" forum, and there are a couple of really active vendors that will help answer your questions accurately and quickly. And, there is a lot of info on the forum already, addressing your specific questions.
Moving...........
Old Mar 1, 2007 | 04:37 PM
Ray@NitroDaves's Avatar
Thanks to 2000GTP for answering the question....did a pretty good job if I say so myself.
please let me know if you have any other questions
Old Mar 1, 2007 | 04:44 PM
danhr's Avatar
atleast get a fuel pressure safety switch
tr6 plugs
a digital 6 to retard your timing (if you haven't had your pcm tuned before you might be fine, if you have, you def need this. Some people have gotten away with < 100 shots without retarding timing on the stock tune.... better safe then sorry in my opinion).
fuel pump
Ideal setup: Bottle warmer with pressure switch.
purge kit
remote nitrous pressure gauge (depending where you mount your bottle)
blow down tube
nitrous filter
possibly a progressive nitrous controller if you really want to get into tuning your nitrous (usually used with the big shots of nitrous, but can be just as benificial with lower shots).
and eventually down the road you are going to need:
clutch
rear end
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
May 25, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
