Newbi need help !!
Old Mar 2, 2007 | 11:59 AM
runninfromthelaw's Avatar
Newbi need help !!
Hey guy,
I have had a hard time trying to get the 12s,parts and setup not working.I have had a best out of this setup of a 13.20@107mph with a 60ft of 2.0 I want one last crack at the 12s with this setup before the new motor.I want to put a small shot of nos to get that 12.99 pass.
My problem is i have no clue what i need to do this i have read the stickys so i know the saftey stuff but what kind of shot will i need.will a 50,75or 100 do?
oh this is on my 95 all mods in sig and i will be running street tires.
Just a few runns just to get this monkey off my back any help please thanks guys.
Old Mar 2, 2007 | 01:08 PM
2000GTP's Avatar
A decent set of drag radials and some better sixty foot times should get you to your goal of high 12s. Most people run 100 shots with no ill effects. As long as you are aware of the "safety gear" that is outlined in the sticky, you will easily spray your way into the 12s. But with that extra power, will require extra traction which brings me back to the begining of my post. Tires, tires, tires.
Old Mar 2, 2007 | 01:57 PM
Ray@NitroDaves's Avatar
I agree with 2000GTP....nitrous will easily put you in the deep 12's on a 100 shot. But a better 60' will get you there also.
I can get you a complete nitrous kit w/all the accessories for ~$875, add the Mallory 685 for $240 and that would round out your system. The window switch include in the package comes with a gear lockout feature that would let you bring the spray in down track to help with the traction problems.
Old Mar 2, 2007 | 02:51 PM
MEAN LT1's Avatar
Ray is the man.
Old Mar 2, 2007 | 10:20 PM
thanks guys
My problem is that every time i do put a good set of tires the drive shaft or the rear brakes.
So i want some thing that will come on after the line so its easier on the drive train till all the new stuff.
Old Mar 3, 2007 | 10:20 AM
2000GTP's Avatar
Maybe you should invest in a better rearend first, then start adding the fun stuff later.
Old Mar 3, 2007 | 11:19 AM
Z-RATED94's Avatar
Exactly, because 109mph is mid 12's no problem, with a little traction.
Z28countrymama
Jan 22, 2015 02:50 AM
ssz28
Apr 29, 2003 05:26 PM
greg biz
West North Central
Apr 25, 2003 01:00 PM
lastZ
Jan 12, 2003 05:29 PM
2000zee28
Jan 11, 2003 09:57 PM
