Nitrous line routing question
Old Jul 8, 2004 | 10:51 AM
LimitedEd1LE's Avatar
I have the NX kit and ran the line through the passenger side under the carpet and now need to get through the fire wall. People tell me there is a gromet behind the computer and I can see it from the engine bay, but not from inside the car. Any suggestions on where else I can run it, or anyone have a suggestion on how I feed the line through the gromet?
Old Jul 8, 2004 | 01:39 PM
LPEdave's Avatar
Well it does come through just up pretty high behind the glove box. Probably if you stuck a screwdriver through from the engine bay side, you could feel around for it up behihd the glove box. Or you could drill another hole in a more convenient place. Either way, make sure there's a grommet around the braided line, you don't want to cut through the wires that go through there, or cut the braided line against the firewall.
Dave
Old Jul 8, 2004 | 02:14 PM
As I recall, you need to pull the passenger side foot well side kick panel off to access the PCM grommet from inside the car.
Old Jul 8, 2004 | 02:31 PM
LPEdave's Avatar
I suppose it could vary by year, but I pulled plenty of wires thru that grommet just by reaching up under the footwell, without removing that panel. I suppose it might make it easier though...
Old Jul 8, 2004 | 11:30 PM
DrewHMS97SS's Avatar
i ran a 4 gage stereo wire through there. there is some plastic that will get in the way if you try to drill above the factory hole.
cmdeshon
Dec 27, 2014 10:06 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
