Nitrous cams, a brief tutorial
Old Oct 16, 2007 | 04:45 PM
  #16
jakesz28's Avatar
I will be talking with a couple people about cams, to see what each recommends. This motor will see the 250 direct port often I just hope it holds together till the end of the year. Then I will really push it. But then there is the LT1 shoot out in April. I just don't know if I want to push it that early in the year.
PM sent.
Old Nov 1, 2007 | 02:58 AM
  #17
rskrause's Avatar
Moderator
PM sent.
So, what did you decide about a cam?
Rich
Old Jan 5, 2008 | 04:42 PM
  #18
jakesz28's Avatar
Well the cam is bigger then I originally wanted. I will be using all of the 2.100 intalled valve height the heads have to offer. I will have an extra 12* duration on the exhaust, 112 lca with 4* advance.
PM sent
Old Oct 26, 2008 | 02:38 PM
  #19
jakesz28's Avatar
Rich
I never got back ahold of you and just saw this thread again. The cam had a 12* split and picked up a second on a .063 jet. I've only giving it a .075 jet need to add a little timing to it but it's been 9.4 @ 140.
Old Oct 26, 2008 | 06:32 PM
  #20
rskrause's Avatar
Moderator
Yeah, the extra exhaust duration (and the resultant earlier opening and increased "area under the curve") DOES make a difference. Like a blower cam but with a narrower LSA.
Rich
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
May 25, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
